Question about Sunbeam 3248 FrySmart Deep Fryer
Deep fryer sunbeam not heating,found part that look like a diode
My fryer does not heat,everything look good but a part i found in the middle of the heating element it look like a diode or resistor it is in between two white wire under the oil pot,please let me know if this could be the problem and where can I find that part in the region of montreal Quebec in canada.thanks
  • 57 Answers
SOURCE: supercontrol de luxe - manual
Posted on Jul 17, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
SOURCE: magnetic breakaway power cord for rival deep fryer
I have a Rival CF-250 cool touch deep fryer. Where do I get the magnetic breakaway power cord, filters, and filter cover.
Please let me know.
Ken Cooley
Posted on Oct 08, 2008
SOURCE: need a manual for a dazey crock pot deep fryer so
Low is generally 200 degrees and high is about 300 degrees.
Posted on May 19, 2009
  • 1970 Answers
mcdevito75 here, Try online at
Posted on Jul 07, 2010
Will not power on, powers off, will not heat Pwr light out or goes out.
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
on Oct 09, 2008 | GE 168997 Deep Fryer
I am trying to locate an Owners Manual for my Sunbeam Controled Heat Sauce Pan model SP 5. Works fine as deep fryer but would like to know what else it can do.
I tried looking for the Sunbeam "SP 5" and came up with a digital scale. A web search for "Controlled Heat Sauce Pan" turned up a paper cookbook How to Get the Most out of your Sunbeam Controlled Heat Sauce Pan for sale for $9.95 (go to item 15 on the page).
Jan 05, 2011 | Sunbeam Crock Pots & Slow Cookers
Jul 07, 2010 | Sunbeam 3247 Deep Fryer
I have a deep fryer. The heating element does not
Probably the heating element or the control has failed.
Feb 16, 2018 | Ultrex 607-922 Deep Flash - Double Filter...
Sunbeam Deep Fryer Model df6300 4litre
FIRST check for a blown fuse inside , that could be it , let me know , AJ
May 18, 2008 | Lang Manufacturing C28 Deep Fryer
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Feb 18, 2008 | Bravetti EP4305FS Deep Fryer
Deep fryer wont heat up
I have the exact same deep fryer and it was doing the same thing if you take out all of the oil and clean it realy good it should work again
Jan 11, 2008 | Black & Decker DF250 Cool Touch Deep Fryer
My GE 168997 is not heating up enough..
call and complain. possibly ask for a now one
Jan 07, 2008 | GE 168997 Deep Fryer
Rival deep fryer not heating
I have a Rival Fryer Model CF250. Was working great for weeks, then after doing a few rounds of wings it quit. All lights were off and no heat.
I took the entire fryer apart and began testing connections for resistance, voltage, etc. They are very basic machines. It appears to me that my failure has to do with a diode, this particular diode sits protected by plastic and held by a srping mechanism, I assume it is the temperature sensor.
I assume that the completed circuit relies on this sensor so it being bad has made power quit.
Nov 03, 2007 | Rival CF275 Deep Fryer
Sunbeam 3248 FrySmart Deep Fryer Logo
123 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
