Question about KitchenAid KGRS807SSS Gas Kitchen Range
Fit a 36 inch gas range into a 40 inch space
I need 2 inch strips of stainless steel as trim.
Where can I get that ???
4 Suggested Answers
SOURCE: Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Posted on Nov 19, 2008
  • 189 Answers
SOURCE: They just installed a kitchenaid 36 inch KDRP467K
Hello- 'They' should have re-checked bus block connections for cord. Element won't work with one leg. If connections look good, check element connections and then power connection for element at board. If it still doesn't work, check resistance of element. Should be around 13ohms. This is the troubleshoot sequence for solution to your problem, but should be under warranty for first year. A piece of advice- avoid the 'self-clean' function. This feature is called 'self-destruct' by techs. Please acknowledge this post if helpful. Have more info if needed. Thanks-  Ed
Posted on Mar 23, 2010
SOURCE: Stainless Steel Range Tops.
The only way to clean it is with steel wool. I use 2 different grades, but finish with a fine grit-0000. You still can't get it completely clean, no matter what you do. Forget it looking new. It's not real stainless steel if it's model FEF455BBA. I won't EVER buy this sort of top again either. I have had numerous problems with it, including since it conducts heat and doesn't shield wiring from the heat generated by the eyes, it is constantly melting out the plug-in elements for the eyes. I am surprised it hasn't been recalled. I am surprised more people haven't had fires!
Posted on Jul 20, 2010
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
I have a black GE Telescopic Downdraft Hood JVB37H1BB. I would like to replace the black trim with stainless steel to match the new cooktop just installed. I don't think stainless steel is available so I...
The trim plate or trim piece is held by part number 38 the slider.The trim plate is just fitted from one side,the other side is just stuck hard,you can say like welded.But its easy to remove,just loosen it from one side and give bit **** from other side and it will be loose.In the inner side of trim plate there are few clips that held it tight.But this clips are very delicate,if this clips are not there,then also trim will fit properly.--------- You will just have to slide the trim plate from part number 39 and it will be loose. See fig for slider, part number 39:--- helpmech_97.jpg see fig for trim plate:-- helpmech_98.jpg -------------- The switch is just held by screws and jumper wire,plug in connectors.This are just pull out connecting wires.And easy to re fit.----------- Check out keep updated.Thanks/.Helpmech.
Mar 14, 2011 | GE Kitchen Ranges
How high is the cabinet under the grill with a 1
The finish height should be 36" from the ground. So you need 34and 1/2 inches then you need to put 3/4" concrete. Then the granite that should be 3/4". You can fudge a little with in 3/8 inch if you need.
Apr 30, 2010 | Fire Magic Aurora A540i-2E1N Stainless...
I'm installing a GE slide in oven. Is there something I can use to fill in the space between the over and the counter top? Have a 1/8 to 1/16 inch gap. Thanks...
Most appliance parts houses have a t-shaped long trim piece made out of plastic or metal that is designed to be cut to fit into this space. Try Reliable Parts at 1-800-666-0313 Good Luck, Appliance Specialists
Dec 14, 2009 | GE Profile JGS968SHSS Gas Kitchen Range
New ge908 slide-in range
The 30" is the widest you can get. I suggest getting a piece of stainless steel and having a metal shop cut and smooth the edges
Dec 20, 2008 | GE Profile 30" Slide-In Gas Range -...
12 inch door problem on model RDS-486GD dual fuel
you can take one of the screws to the hardwere store and get a self taping screw, or a screw one sides bigger. or you can use a ribbit, that will take care of it.
Dec 11, 2008 | DCS RDS-486GD Stainless Steel Dual Fuel...
THE STYAINLESS STEEL COOKTOP
I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
430 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
