Question about Motorola Mobility RAZR V3
Cant text in t9 mode
When I try to send a text in t9 mode, nothing shows up. It acts like Im not even typing anything. Any way to fix this?
    Brigadier General:
  • 7,752 Answers
A master reset of the phone will help
Posted on Dec 28, 2008
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
When I am writing a text message the phone starts predicting words. I just want to send a simple email without any ''help''
If you are seeing the T9 icon on your screen, this is the T9 Text input feature of your phone. It act's like a built-in dictionary for commonly used in a sentence.
To disable this, while on writing mode, press and hold * key to disable text input.
Sep 25, 2009 | Sony Ericsson K850i Mobile Phone
Can i transfer my saved T9 words from my old phone in to my Nokia
No, you cant do that. What you can do is that you canconnect the old one to your laptop and copy all sent msgs to a notebook file (if you havent deleted them already). It will contain most of your Welsh T9 words. Make a file and email to yourself. Receive it on your new phone and open this email and select and copy the text of this Welsh words. Send a msg to some one after pasting all this txt. All the best to you.
Jul 31, 2009 | Nokia N96 Cell Phone
Predictive text on Samsung Propel
Well it's not so much a solution as it is an answer.
T9 is 9-key Texting. So it will only predict what you're going to type if you're using the 9-key triple tap mode of texting.
It WILL NOT intelligently select options of what it thinks you are typing on the QWERTY keyboard.
I've had this phone for less then a week & so far that would be my only suggestion for improvement. Otherwise, it's an awesome lil' phone for what I use it for.
Feb 19, 2009 | Samsung Propel A767 Cell Phone
Cant set T9 as the default entry method on LG cu920
yes you can set T9 as default on the Vu just go to the new message touch options and touch text entry mode and touch T9 Abc and that will become your default
Dec 24, 2008 | LG Vu CU920 Cellular Phone
My texting is messed up
the phone is just slow but if you want it replace just take it in if it is still under warranty
Nov 30, 2008 | Sanyo S1 Cellular Phone
Texting and taking off the t9 feature of assuming what im going to type
sometimes it will pop extra words up like that for me, but i found that if you just ignore it and keep typing, they will go away. try it :)
Aug 18, 2008 | LG Shine KE970 Cellular Phone
No texting on motorola v557
most of the problem like this is from the cell provider or line provider ask them to activate the outgiong text.... Probably you need to bring your cellphone to them to test the result of activating the text outgoing.... Hope this will help you alot,,...
Jun 15, 2008 | Motorola Mobility V557 Cellular Phone
Texts random letters and then sends on it's own
have you tried to change the TEXT T9 from iTap to just ENGLISH
Dec 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
