Question about Kenmore Elite HE4 Electric Dryer
Burning smell the dryer HE4 is only 1 year old and I am single so I do not do a lot of laundry. The last time I used the dryer last week I could smell something burning. The clothes dryed so I did not think anymore. Then I used the dryer again and the same smell and the dryer read PF and would not start up again. We did not have a power surge at all. After a while it did start up and I dried the clothes. When looking at cord the three prong plug was melted to the electrical box on the wall and there was a light brown going up the wall from the box.
  • 706 Answers
Hello benson131,
Based on your description, you already identified the problem as being a bad power cord. There is a high probability that the place where that cord is wired into the back of your dryer that the terminals worked themselves loose. Loose terminals become resistive and do not allow adequate current flow to maintain dryer temp so more current is required and that additional current will cause the insulation to melt on your power cord. I suggest you do the following. First off, unplug that cord from the wall recpetacle. Determine if you have a 3 prong or 4 prong plug. Go to a local home goods store like Home Depot or Lowes to get a replacement cord set that matches the one you have.. ( probably cost between $10 - $15 ) Once you have the right cord.. pull the dryer out and away from the wall.. Locate the feedthru on the back of the dryer rear panel.. ( that is where the cord goes into the dryer) and usually has some kind of cable clamp to keep the cord from being yanked out of the dryer.
Loosen the cable clamp and then look for an access panel where the wires physically get tied into the dryer. Once you have the cover removed, you should see a terminal block with 3 or 4 positions and color coded ( red/ white/ black and or green.. ) the Green is a ground wire and may be secured to a frame stud and not on the terminal block. Unscrew the wires from the old cord and reinstall the new cord in its place. Make sure you match the colors correctly ( red to red, white to white,black to black and green to green if it has a green position of green to a frame screw.) Make sure these wire terminations are reasonably tight. Once together, put the cover back over the terminal block and make sure the cable clamp is snug. Then plug it in and run it.. Your problem should be resolved.
Let me know if you have any questions with this...
Regards,
Rick
Posted on Nov 25, 2008
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Our kenmore dryer is 6 years old , model# 110.63102101 at first the drum wouldn't turn,and we would get it to turn by using our hand , last week it smelled liked it was burning, so let it rest and then it...
In your case the motor probably has gone bad....you are looking at a 200-400.00 repair, so go from there...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 04, 2010 | Kenmore 62602 Electric Dryer
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
