Question about Microwave Ovens
My lower oven does not work; top oven works fine
It's a (gas) Roper in wall double oven
  • Microwave Ovens Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" (tech sheet) hidden inside the unit behind thecontrol panel or hidden inside behind the back cover, etc., and it's very helpful when troubleshooting, testing, and locating components.
Posted on Nov 25, 2008
Model 8006262000
I assume your oven is electric and not gas? If so, consider replacing the fuses on the oven, which are located in the back. THese fuses are pretty cheap, just ask around at the hardware store. This should fix your problem.
Dec 05, 2013 | General Electric GE 27"" Built-In Double...
I have just moved into a 10 year old house. It has Blanco gas cook top and a Blanco wall oven. My problem is the electric starter for the gas top does not work. and the Oven indicators eg. top element,...
#1 You may have a blown fuse which sets all these issues together
#2 Your sparker may need to be tested, try a voltmeter to it and see what it reads. If voltmeter reads voltage, then it's a simple adjustment of distance to contact. If no voltage, then you'll need to replace sparker.
#3 as far as your indicators, that has to be an internal fuse.
I agree with you for not replacing these appliances, I love to cook with gas
Dec 16, 2010 | Microwave Ovens
I have a Thermador ME272 double-convection wall oven. After self-cleaning the bottom oven, the bottom oven won't turn on. When I press Lower Oven or Self-Clean on the control panel, I get no beep and...
I would almost guarantee the thermocouple is bad.It is a small rod whose wires come out from the back wall into the oven and is mounted inside the oven,usually near the top.This is a common fail component in ovens due to the temperatures it endures over time,especially with self-cleaning because they usually go over the maximum temperature cooking allowed during cleaning.If you want to test it yourself,you or someone can swap out the 2 thermocouples as they should be identical..Make sure the circuit braker is pulled first.Behind the oven there is probably a cover which is fairly easy to access.If it is possible to switch the 2 connectors without removing the thermocouples,it would obviously be much quicker.If you switch them and turn both ovens on,the problem should switch ovens also.If you switch the thermocouples and the problem DOES NOT switch ovens,the bottom doesn't work but top still does,the circuit board is bad.Wait about a half hour before touching the thermocouple after heatup and leave the door open.Good luck,Greg
Nov 20, 2010 | Microwave Ovens
I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Jan 20, 2010 | Roper MHE14XKB Microwave Oven
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Rita
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Mar 22, 2008 | Microwave Ovens
Amana ACE208 doesn't work with a message 'door'
The door latch receiver has a spring action lever (inside) that is made out of plastic and cracks or wears through. You need to remove the cover and remove the two screws holding the door latch receiver. Now you can switch the top and bottom piviot switchs, putting the top one lower and the lower one on top..make sense? you"ll understand when you see it.
Feb 26, 2008 | Amana ACE208 Convection/Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
