Question about Samsung DVDR120 DVD Recorder
Player freezes at same time on almost every disk, and recorder programs won't play on anything else.
My problem is two fold.. First, the dvd player will freeze at 1 hour 15 minutes into almost every movie. Cleaning the disks doesn't help. Secondly, if we burn a tv show we can only watch it on that dvd player. It won't play on any other player, or computers. Any suggestions?
  • Karen Wondergem Jan 02, 2007
    You are my new best friend. I feel like an idiot, I never finalized any of the disks.
    As for problem 2, yes they are commercial disks. It will start mini freezing at around 1 hour 15 minutes, skip, and then lock up about a minute later. It doensn't do it on every one, about every other one it will.
  • 624 Answers
The last problem is probably because you have not ?finalized? the DVD yet. Basically what that does is modify how the data is stored on the DVD so that a normal DVD player can read it. It also prevents you from modifying or recording to the disk any more so make sure you?re done before performing this. The part about the freezing is more complex, are these commercially recorded DVDs or something someone else recorded?
Posted on Jan 01, 2007
  • tomj23 Jan 02, 2007
    Thanks for the kind words, my manual wasn't very good and treated that topic as an afterthought. As to the other problem??.
    The data is recorded on the DVD starting on the outside and working its way in towards the center. The closer to the center the more difficult it is for the drive to read or write so minor problems on the outside of the disk don?t affect it as much as ones on the inside. One hour and 15 min is fairly far into the disk so that might explain what?s going on.
    As to why:
    -Perhaps your players read/write heads need cleaning. If you haven?t done so recently you might want to pickup a DVD player cleaner disk where you got your DVD player and run that.
    -Another possibility is the disks themselves. The ones we rent from Netfix or the local rental are for the most part in bad shape. They all have scratches and *stuff* that defies analysis on the top and bottom of the disks, all of which can affect the play. About one out of twenty we rent stop playing, usually after its past 2/3 of the play time. Sometimes I can work around the problem by cleaning/polishing the gunk and scratches off them. I picked up a nice $20 Memorex model where you place the disk inside, apply some polish, close and use the handle to polish the disks.
    Again let us know how it goes
SOURCE:
Samsung R150 DVD recorder system error and freezing.
go to menu, select formate, formate disk in V mode not VR.when finished recording finalize disk. you can then play on any dvd player.
Jul 10, 2009 | Televison & Video
Can't play recorded DVD's(from philips 3505) on other dvd players
Hi I am Vortash It very much sounds like you are not finalizing your disks .. any dvd recorder that makes a disc from computer dvd's to free standing unit s work on the same software principle , however the programs do differ slightly and finalisation stanard izes the disc to run on any player, without it another recorder will either not recognize the disk or the language it is written in . Read that message at the end and you will see the option to finalize or it will say do you wish to be able to play this on another dvd or it will do it automatically if you set it to do so in the menu on some sets .
if your player isnt doing this it is not set to do so in the menu settings disks can be finalized at any time after recording providing they are not over filled as the finalization process will take up at least 10-12 mb some do it in more some might do it in less depending on the software hope this helps Regards vortash
May 17, 2009 | Philips DVDR3505/37 DVD Recorder
Pixellated and freezing
hi most of the time a cleaning disk or canned air is not enough but you can tray it, you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful
bye and good chance.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Playing burnt DVD disks on other dvd players
It is very possible that the head alignment on your DVD recorder is a little out.
Also, make sure that you are closing the session after doing the recording (burn). If the session is not closed, the DVD will not be playable on other players.
Jerry G.
Aug 10, 2008 | LG RH1777 DVD Recorder
DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Jun 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Picture freezes
Is this problem happening when playing back from DVD, VCR or internal disk?
Sep 30, 2007 | GoVideo DVR5100 DVD Player / VCR Combo
Samsung DVDR120 DVD Recorder Logo
347 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
