Question about HP Office Equipment & Supplies
My hp 3055 all in one has a problem with receiving faxes on a single phone line. Does the fax has a setting to know if someone sends a fax or if it a voice. I had a friend send me a fax I let the phone ring until the fax pick it up and work find, but when he sent it manually from his end it didnt work he said it just rang and rang unitl I picked up. Thanks for your help Larry
    Genius:
  • 2,120 Answers
Unplug the power cord for 10 seconds.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE
Posted on Nov 25, 2008
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Jul 08, 2009 | HP LaserJet 3055 All-In-One Printer
I can send a fax, but not receive one.
re-install your 3055. check for the manual on HP website. download it.
plus you may need a filter on your phone...fax boards are very sensitive to online static.
Jul 03, 2009 | HP LaserJet 3055 All-In-One Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Stopped Receiving
use the print menus option in information, it should show the menu path settings
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 Lasrjet
receive set to manual set to automatic
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
My hp 3055 has not been receiving any faxes
The only thing that I can think of for you to do is to completly delete it from your computer & then re-download it. Only do this if you get no other resolution. Or you can call 1-800-474-7739 for hp technical support. I just did & they were a great help to me!
Jun 05, 2007 | HP LaserJet 3055 All-In-One Printer
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
