Question about Fujitsu fi-4340C Flatbed Scanner
Duplex scan - top page half missing
I am using the Fi-4340c with the ADF attachment. I have a two sided form, recently it has stopped capturing the full image from the top scanner lens. I replaced the lens, bulb, led...what ever it is. and that did not correct the problem. any suggestions? are there bit switched or something that I can adjust?
Thanks
Michael Blakeley
michael.blakeley@csmd.edu
Roshan89
  • 271 Answers
SOURCE: Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Posted on Aug 15, 2008
  • 3 Answers
SOURCE: How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Posted on Jan 20, 2009
VRSKING
  • 31 Answers
SOURCE: Fujitsu fi-4340C changing the bulb
Open up the ADF ****.
Remove Two Silver screws holding front
of top cover.
Remove screw from ADF release button.
Pull back of top cover to unclip.
This will enable you to see the rear lamp bay
and camera unit.
Lamp is situated under Camera unit.
ADF = Auto Doc Feeder.
Posted on Jun 10, 2009
  • 16 Answers
SOURCE: fujitsu fi-4340c scanner not scanning all of back side of page
these rear camers get the board that has the CCD chip on it come loose from the camera. take off the ADF cover, at the from of the rear camera you will see the board held on with 2 screws, there have probably come loose. you will need to tighten them up with the board in the right place to allow the image from the camera to be focused on this chip. it will take you a while to get it in the correct place, but once you have it correct, the image will be perfect again. let me know how you get on
Posted on Sep 16, 2009
  • 16 Answers
SOURCE: Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
The rollers in ADF are not moving
select in software - adf front side , back side or duplex then only it will scan from adf.If you have selected adf and its not scannning then pls check whther the rollers are rotating or not.
if still problem remains mail me on felixsimon22@gmail.com
Feb 17, 2011 | Fujitsu fi-6770 Flatbed Scanner
How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
when happy with your settings click OK again, then apply.
Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
Hope this helps!
Nov 10, 2010 | Fujitsu fi-5120C
How do i reset the pick roller counter on my 4340c scanner?
First go to this site: http://www.fujitsu.com/downloads/COMP/fcpa/scanners/fi-4340c_maint-guide.pdf and download Fi4340c PDF, look over directions on cleaning Pickup Rollers be careful with handling delicate plastic moldings. After a good cleaning Test Unit. Now left ADF unit back as to service and power off a minute or 2. This should reset and bring back the normal "ready" display.
Jun 02, 2010 | Fujitsu fi-4340C Flatbed Scanner
ADF is starting the page scan about 1/2 inch above the top of the page
Pop open the cover and clean the rollers with alcohol. Your feed pad could be worn out also. Make sure the feed switch actuator is not sticking.
Jan 05, 2010 | Fujitsu fi-4340C Flatbed Scanner
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Fujitsu fi-4340c scanner not scanning all of back side of page
Jul 08, 2009 | Fujitsu fi-5750C Flatbed Scanner
of top cover.
and camera unit.
Jun 09, 2009 | Fujitsu fi-5750C Flatbed Scanner
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
Fujitsu fi-4340C Flatbed Scanner Logo
67 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
