Question about Car Audio & Video
NO SOUND FROM MY GPS HELP HOW CAN I FIX IT
VOLUME WAS WORKING BEFORE AND KNOW IT'S NOT IT'S NOT MUTED THE VOLUME IS WHERE IT SHOULD BE TRIED EVERYTHING FROM RESETING IT. TO CHECKING IF WAS MUTED TO CHECKING IF THE VOLUME WAS LOWERED BUT IT'S NOT HELP!!!
    Problem Solver:
  • 12 Answers
Speaker may be broken no easy fix to this if its not muted. try and bring it back to where you bought it they may be able to help you or try and find a local electronics repair place.
Posted on Dec 10, 2008
My GPS is working well but without sound. What can I do ?
The volume may be turned or mute/ Turn up the volume or turn on the sound output. (source- http://www.manualslib.com/manual/111053/Nextar-M3-06.html?page=21#manual)
Apr 21, 2012 | Nextar M3-06 GPS Receiver
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
How do you reset a garmin nuvi 250w? The sound does not work.
ok don't know what you mean by sound dont work, when driving cant hear street names?
a couple things to try..
on the screen click volume icon... does it have a checkmark in mute ? if not on bottom of screen you will see FM Trans..... press it.....is there a checkmark in Enable if there is uncheck it
Oct 23, 2010 | Garmin nuvi 250W GPS Receiver
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
The volume has been set to mute, yet I cant seem to find how to turn off. Its not in the volume controls. Mytec 5" Slimline GPS
so what's your point? The sound is not hearing when it's muted, it's the same thing like sound off.
Aug 10, 2009 | Mitac GPS
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Tomtom one xl
Either the volume is right down or the mute is on. The volume is generally adjusted by touchscreen-I think it is on the right hand side-cant remember if its top or bottom. If that is fully up then its muted. Look through your menu and somewhere in the settings or sounds you will see an icon of a speaker. There may or not be a red cross over it. You need to put mute off.That should restore your sound.
Jun 11, 2009 | Tomtom GO GPS Receiver
No volume on my F20
It sounds like you have muted your F20.
If this is the case you need to turn on the Sat Nav (outside so it picks up the Sats). Once the sats have loaded and machine is working. Press the arrow button bottom right, which takes you to map pages, press the screen on an empty area on the map page. This will bring up another on screen menu which gives you another 6 options (these include pausing routes, brightness etc..) one of the options is 'mute' (top right on screen button) press the button once and you should be un-muted.(It is one press to mute and press again to un-mute). Once un-muted, use the side + & - keys to raise and lower volume.
Hope this helps, if you are already un-muted and still have no volume, you may have a faulty unit. You could try a master reset by inserting a pin into the reset hole on the bottom of the unit.
Feb 01, 2009 | Navman F20 GPS Receiver
No Sound
Is there any mute/unmute or volume control on the GPS? If so, is the mute/unmute function unmuted, and is the volume all the way up? If you have already checked this stuff, then would say that the device is bad (in which case you can probably send it back to Magellan for a replacement) or the speaker was somehow disconnected( in which case you can't fix it). Has the audio ever worked?
Mar 15, 2008 | GPS
I can't get any sound out of my monitor. when I push the select I get the speaker w/music, select that.My color on th volume is green. I get no sound. I try to push the 1-2 reset button and nothing changes...
First use a try testing another source of sound, (say an Ipod or cd player) instead of your computer.
If that works the try troubleshooting the mute and volume controls on your computer.
Mar 13, 2008 | NEC AccuSync LCD223WXM Monitor
Car Audio & Video Logo
216 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
