Copystar cs-2050 all my copies or prints come out with a red and blue mark down the length of the paper. ive tried to clean out everything but no helping. any suggestions?
    Genius:
  • 2,120 Answers
Your developer units are leaking.
Posted on Nov 26, 2008
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
Apr 07, 2014 | Copystar CS-2050 All-In-One Printer
HOW TO CHANGE LASER UNIT COPYSTAR CS2050
laser unit is under cover where copies exit, remove cover unplug laser unit and then remove 4 screws holding it down. replace unit
and scerws and plug in unit and replace cover and all is well
Oct 12, 2012 | Copystar CS-2050 All-In-One Printer
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
My Kyocera Copystar CS-2114 Copier is printing a one inch black line of the left side of the paper
have a look at the scanner glass especially the thin strip glass this is the glass that is used when passing paper through the document feeder. if you do a copy from the main glass or print to it and no line apears there is probably dirt or tipex or a ink mark on the surfac, the other thing to look at os the drum charge unit as htese can sometimes fail to connesect correctly at the back and not sit tight in the slot this means the drum isnt charged on the edge.. good luck
Nov 17, 2009 | Kyocera Copystar CS-1620 Black and White...
Kyocera cs 2050 copy has faded print down center
make sure the glass is clean it sounds like you either have a dirty scan glass or the wires need to be cleaned there should be a cleaner on the front cover of the macin that you you pull out and slide back abd fourth to clean it
May 05, 2009 | Kyocera CS-2050 Black and White Copier
Red and blue marks on copies
The CS 2050 is a mono color (black only) copier. There is nothing within this machine that I have EVER seen that has red and blue "ink" in it. I suggest you look at the paper that is in the tray itself. I have been on many service calls where the customer said the copier was tearing off a diagonal corner of the page, or the copier was putting something on the page that it was not capable of doing. When I looked at the paper in the tray I would find that the paper itself had the defect before it ever even went through the machine. Since there is 500 sheets per ****, and you may only see it on every 20th or 30th copy, you will have to either just try a new **** or go through whats in there 1 sheet at a time looking at both sides. But, if you find something that has blue and red ink within this machine please let me know.
Nov 24, 2008 | Copystar CS-2050 All-In-One Printer
Copy star 3035
The drum unit may need to have the toner collection blade replaced. not the cleaning blade for the drum but the one below it that catches the toner cleaned off the drum. if this blade is old or damaged it losses its seal to the drum and drops tiny specks of toner onto the page.
Hope this helps...
Lbcoast
Aug 20, 2008 | Copystar CS-2030 Copier
Copystar CS-1810 instruction book
manual download link
http://usa.copystar.com/CopyStarPub/jsp/Kyocera/resource_details.jsp?rid=2076
If it only has lines on copys then
Clean scanner glass (small slit of glass before copy glass)
If it happens on prints and copys then it will more likely be drum.
Nov 10, 2007 | Copystar CS-1810 Copier
k24674
jasbo
jasbo
Marvin
Marvin
