Question about Brother CS-100-T Computerized Sewing Machine
Presser foot down, but still get error "E1"
I get an E1 message when I begin to sew. The manual says the presser foot is not down, but it is. We tried cleaning, opened it up, everything is working normal except for that error. It won't sew at all. Any suggestions?
  • 4 more comments
  • Karen Wondergem Jan 02, 2007
    Never mind, I took it apart and cursed it's name until it worked again. The thing was on the wrong side of the other thing, causing it not to work. :)
  • sewinghell Apr 12, 2008
    I get the E1 message saying the presser foot isn't down, but it is. What thing was on the wrong side of the other?
  • Anonymous Jul 12, 2008
    I have the same probolem as well
  • Anonymous Nov 10, 2008
    same problem
  • Anonymous Mar 13, 2014
    E1 error says pressure foot is up and machine will not operate even though foot is down
  • Gail Williams Sep 10, 2014
    I need a better answer for this problem.
  • 3 Answers
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Posted on Aug 04, 2008
    YES!!! Thank you, thank you thank you! I had had the cover off tho replace the bobbin winder tire but it worked after that so I didn't know what had happened.
    New Friend:
Thank you!! I found someone else who said to have the presser foot up and put it all back together... Problem didn't resolve. Tried it this way and it worked!!!
Posted on Mar 15, 2013
    Problem Solver:
  • 8 Answers
It worked! I thought I broke something when I opened up my machine. Thank you, thank you!
Posted on Aug 10, 2012
SOURCE:
Error message on Pfaff 7570 is "bring presser foot lifter to sewing position?" Is this a fatal error or is this a procedure that has to be done before the machine will operate?
Assuming that the presser foot lifter is working, this shouldn't be a fatal error. The presser foot has to be down to sew. The lifter needs to be in the down position to put the foot down.
The manual for the Pfaff Creative 7570 is available on the product page: http://www.pfaff.com/en-US/Machines/creative-7570 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_7570-manual-EN.pdf?ext=.pdf . See page 32 (page 36 of the PDF) of the manual to see a picture of the presser foot lifter.
I hope this helps.
May 27, 2018 | PfaFF Sewing Machines
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
E1 error brother ce 4000
Hi.
You can get the E1 error if the presser foot is not down. If you use the walking foot attachment it can keep the foot from coming all the way down.
Apr 08, 2017 | Brother CE4000 Computerized Sewing Machine
Brother ce5000prw e1 code
Presser foot sensor/switch is either stuck or broken.
Jul 19, 2014 | Brother Sewing Machines
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
Persistent E1 message
some machines have a presser foot sensor or switch which prevents the machine sewing if the foot is not down.
if your presser foot is down and you still cannot sew the switch or switch actuator is most likely damaged. you will require a tech to repair this.
scott
Jul 26, 2009 | Brother CS6000i Computerized Sewing...
Brother CS-100-T Computerized Sewing Machine Logo
879 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
