Question about Cobra 29 LTD CB Radio
Cobra 29 ltd modulation problen
My cobra 29 has low modulation. its not a mic problem because, the mic works fine on my other 29. with the dynamic turned all the way up, i only get half scale. i know it would normally peg the meter. any suggestions?
  • 211 Answers
You need to check the modulation on a modulation meter. Just because the meter doesn't peg, doesn't mean the modulation isn't working. Usally a meter pegging, means the swr's are too high or the meter is misadjusted. If in fact the modulation is low, their is a pot inside the radio (VR4) that will add gain to the modulation circuit. This setting is legally supose to be set by a qualified technician.
Good Luck
Ed Meshechek ( Radio Man )
NC Electronics
PO Box 1696
414 6th St.
Mills, Wyoming
Posted on Dec 03, 2008
Where can I find a new replacement modulation transformer for a cobra 29 ltd classic?
simple,just chech the input resistance and out put...they should have even small resistance always example .5ohms .3 ohms it counts...
Feb 01, 2014 | Cobra 29 LTD CB Radio
Hi,i have a cobra 29 ltd radio .the problem is this i can hear prople great but when i key up people barely hear me even thou i have my mic gain up and dinamic up as well. also when i key up my cb makes i...
You said mic gain and dynamic as well. After market power mic? Battery in power mic good? and is it wired for that radio? Running a "mag mount" antenna? Make sure your radio "power" itself has a good ground. In some cases the chassis of the radio may have to be grounded as well. Your getting some type of feedback, whether its audio or RF related just might have to play with it a bit.
Nov 11, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
My Cobra 29 LX receives including the weather but can't transmit
If the relay contacts are closing. You may have blown the output transistor, however a broken wire in the microphone can also create the symptoms you describe. .
you can check by using a #47 light bulb soldered to a PL259 connector as a dummy load. If it lights, the carrier is present, but you may not have voice modulation which will show as differences in light intensity as you speak. If no modulation, the microphone is the first thing to look at.
The relay contacts may also be very pitted or corroded and not achieving continuity.
Feb 17, 2012 | Cobra 29 LTD CB Radio
Cobra 29 cb receives well, but no one can hear me when I transmit?
open the radio and turn vr 4 wide open but before you do get a new mic and hook it up to eliminate the squeal the turn up vr 4 to raise the modulation.
Jan 13, 2012 | Cobra 29 LTD CB Radio
Cobra 29 has a 5 tone roger beep . It works fine with a stock Mic . But when I use a d104 I get about a 2 second hum instead of the beep.Any ideas on what is causing this. Thanks
The d104 is a power mic. For what you have explained you have something gone array in your mic or the mic plug. The fact the d104 is a power mic should not make anything hum. With a lot of power behind your CB and the power mic things can sequel with the mic gain turned to high. But a hum is more than likely a bad mic. Try another one. The same kind of mic should be fine.
Jan 24, 2011 | Cobra Radio Communications
Hello i own a cobra 29 ltd classic from 1993 today i was talkin skip like crazy!! running about 100 watts out of a texas star modulator!! i left for a while came back talked for a while everything was good...
sounds like the amp got hot and shorted on the bias.. and is keyed up a few watts. to fix you will have to have the amp repaired. new power transistor. to fix. 3174269649 Texas.
Dec 12, 2010 | Cobra 29 LTD CB Radio
Cobra 29LTD CHROME low tx no mod, rx good low Vol, talkback good
1 why would you change the finals?? Have you checked you antenna? How are your SWR's? Crappy antenna's cause a lot of problems.
Use an external meter to see what the SWR is, and see what the output is PEP. If its low, then there is something wrong. If it is High, change the mic and turn up the dynamic all the way.
Next. Have you been messing around in there?? Tryin to get more wattage? You turned VR4? If you thought you were turning it up by turning it all the way to the right, you turned it all the way down. Turn it all the way to the left.
Jun 05, 2009 | Cobra 29 LTD CB Radio
Modulation sounds bassy!!!
first change mic ,maybe the problem are in this mic ,second if the mic is ok verify all capacitors in the modulation near of this ic ,if all are ok change the modulation ic and change it, i hope this help you
Apr 12, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
551 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
