Question about Drills
I need a cutaway diagram for my Craftsman 15 1/2'' drill press.
I need a cutaway diagram of my drill press. A mouse built a nest in there and it won't work properly. Thank you.
  • Carl Blank May 11, 2010
    Need brannd and picture if possible
  • 2,176 Answers
You need you exact model number and go to Searspartsdirect.com and you can view a schematic online or print one out. If you have trouble let me know and I will see what I can do.
Posted on Jan 07, 2009
Manual for model# 24580
manual below,second link lets you down load it
press the helpful button and follow me on fixya for more tips and help
1969 Craftsman 113 24580 Bench 113 24590 Floor 15 5 Drill Press Form 3478
http://www.vintagemachinery.org/pubs/detail.aspx?id=4824
Jan 31, 2016 | Craftsman Drills
113.24520 chuck replacement
most drill press chucks are installed and locked on by a male / female taper fit. Tap chuck assy. downward with a soft hammer to remove. install new chuck tapping it upward.
Oct 28, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
Have a Craftsman 15in. to a 17in not sure, drill press and have lost the chuck a #2 taper. Can buy one at Harbor freight For their Mini Lathe,can you tell me if it will work?
#2 taper should be the same on all machines .... for peace of mind ask the shop if you can return it,, if it does not fit ,,, i think it should as i have used tapered chucks from drill to lathe on many occoations,,, pete
Oct 04, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
There isn't a manual for our craftsman 21914 drill press. We need to know how to put it together.
Use this link to get to the Sear page showing exploded parts diagrams for your drill press.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Drill-Parts/Model-315219140/0247/0713080?searchedModel=21914&blt=
If you click on the tab to "search by part description" you can enter "manual", then you can order it for $2.16, it you still need it.
Good luck, Al K
Feb 02, 2011 | Craftsman 12" Drill Press (21914)
We have a craftsman 15" drill press. The arm on the side that raises and lowers the bit will not stay up. Never had this happen before. any ideas?
There is a spiral spring on the left side which has failed. It has a cover that looks like an undersized hockey puck (usually chromed). The spring has either slipped out of place or is broken. Carefully remove the cover, (leaving the spring in place) to investigate.
May 25, 2010 | Craftsman 11321371 Drill Press 1512" Part...
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Drills Logo
745 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
