Question about HP Pavilion ze2000 Notebook
Wireless does not work on hp pavillion ze 2000 after xp reinstall
I reinstalled windows xp service pack 2 on the laptop all the drivers are installed but I cant get the wireless to work. There is a wireless button on the laptop. When I press it it says wireless disabled if I press it again it says wireless off then it says wireless disabled when I press it again. I'd appreciate any help.
  • 2 more comments
  • witt9je Nov 25, 2008
    I have checked to see if the wireless network connection is enabled and it is. I also tried repairing it. Also I checked to see if I had a driver and that the hardware was working properly and both checked out fine.
    I suspect that the problem has something to do with the hp wirleless assistant as it toggles "off" and "disabled" but not "on". Not sure what to do or how to fix it though.
    Reinstalling a new version hp wireless assistant seems to have fixed the toggle issue at least. Now it goes to "wireless on". I have to test the wifi now.
  • witt9je Nov 26, 2008
    Wifi works after hp wireless assistant uninstalled and then reinstalled.
    Scholar:
  • 162 Answers
Try this to check the wireless.
Click on start> Control panel> network and internet connection> from left pane click on view network connection after that right click on the wireless adopter icon and select enable.
this will resolve the issue if it is not helpful
try to check wireless driver from
1) Go to Start, right click My Computer and then click on Properties.
2) System Properties window will appear. Go to Hardware tab and click Device Manager.
3) Device Manager window will appear, and you can check all hardware drivers' status here. Scroll down and look for Network adapters and expand it, then right click the wireless adapter you want to check and click Properties.
Posted on Nov 24, 2008
    Novelist:
  • 100 Answers
Let's make sure the WLAN adapter is enabled in Windows, too.
Click Start => Settings => Control Panel.
Double-click Network Connections
Right-click on the wifi adapter
Look to see if Enable or Disable is present
- If Enable, the device is OFF
- If Disable, the device is ON
If Enable is in the dialog box, then click it.
That will turn the wifi card ON.
Try the wireless button on the laptop now.
Check that out and then let me know the results. We'll go from there!
If this doesn't fix the problem, please don't rate the solution just yet. There are more steps we can take to troubleshoot the problem. My goal is always FixYa or Helpful, never TFT or IA.
Regards,
Char1ieJ
  • Charlie Jarman
    Charlie Jarman Nov 26, 2008
    GREAT! It sounds like you're making good progress. Once you test the wifi, please let me know the results. We can go from there, *IF* it's not fixed. THANKS for following up with me.
    Regards,
    Char1ieJ
HP Pavillion ze 2000 has no wireless connectivity
Try installing the latest audio and LAN drivers.
You can download the audio, LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 10, 2012 | HP Pavilion ze2000 Notebook
I have two problems with my HP compaq 6830s running VIsta business SP2 1) My inbuilt web cam stopped to work, and i have tried to uninstall and reinstall drivers with no luck. 2)The wireless card,...
If you upgrade your operating system like from windows xp to windows vista, you need to install new hardware driver for your computer like for LAN, webcam, WAN and others because the old driver is only compatible with the old operating system and not with VISTA operating system. Solution would are, download webcam and WAN driver for Windows Vista and install it into your computer. Don't just upgrade your computer because the configuration is not the same with the old operating system. If problem still exist, just upgrade the service pack from 2 to 3. There is available install for upgrading the service pack of each operating system. and surely all your hardwares will function.
Dec 29, 2010 | HP Compaq 6830s Laptop
MY HP PAVILLION DV 1000 HAS NO SOUND DEVICE NOW
Below is a link to download the sound drivers for your laptop. Download, install and reboot and everything shoud be fine.
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Jan 22, 2010 | HP Pavilion dv1000 Notebook
Hp pavillion ze 4300 will not boot past windows (blue w. icon) screen if i load from windows xp cd will this erase hard drive?
what operating system are u using currently?......if u r using win Xp it will not erase hard disc....load the cd and select repair.
Nov 11, 2009 | HP Pavilion ze2000 Notebook
No wifi after re-load of xp system software
Did you reinstall the drivers for the device? Check the Device Manager for your system and see if Windows sees the wireless device. If you have a red X, the device is disabled; if you have either an unknown device or the wireless device with a yellow dot with a black exclamation point, then either the driver is not installed, or the driver is improperly installed.
Mar 24, 2009 | HP Pavilion zd8000 Notebook
Windows vista to windows xp sp2; the VGA and wireless don't work
uninstall the wireless driver and then reinstall it again and then install the vga driver and do the wireless configuration from the router page,and then try and install the wireless driver of xp and also install the vga driver of xp.......good luck.....
pls rate this solution
Feb 16, 2009 | Microsoft Windows Vista Home Premium with...
Drivers and installation
U COULD TRY REINSTALLING WINDOWS.AND SERVICE PACK
Sep 21, 2008 | Computers & Internet
HP Pavilion ze2000 Notebook Logo
1,748 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
