Question about HP PSC 750 All-In-One InkJet Printer
How to check the ink levels
Hello I have a HP PSC 750 All in one Ink jet scanner/copier.
I would like to check the empty cartridges to see exactly how much
ink that is actually left in the cartridge. How do I do this?
Thank you in advance for your help!
Husband fixed it. :-)
Posted on Nov 25, 2008
How to change ink cartridge hp psc 750
1- Open the printer
2- Remove the ink cartridges from the print head.
3- Use cotton swabs dipped in hot water to thoroughly clean the print head.
4- Repeat this until there is no ink residue coming off on the cotton swab.
5- Once finished, allow to dry and replace the cartridges
Mar 19, 2013 | HP PSC 750 All-In-One InkJet Printer
My printer is printing blank pages.
Either:
* empty ink cartridges
* clogged ink-jets, such that no ink can be sprayed onto the paper
Use the HP software to check the ink-levels in the cartridges.
Run a few "print-head-cleaning" cycles. If still no output, then replace the ink-cartridge(s).
Feb 22, 2011 | HP J4680 Office Jet All-In-One Printer
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Oct 05, 2010 | Office Equipment & Supplies
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align...
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Sep 28, 2010 | HP PSC 750 All-In-One InkJet Printer
I want to use only my scanner without cartridges, what should i do ?
You can use it but Cartridges should be in the printer ( atleast low on ink message )
If you want to scan ( with empty ink cartridges ), the printer should be aligned first
Jun 16, 2010 | HP PSC 750 All-In-One InkJet Printer
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
3. Press the change cartridge button. It is at the top of the printer next to the power button.
4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
I have a hp psc 750 and have just put a new black ink cartridge in and keep on getting the error message wrong black ink cartridge
Did you make sure you removed the plastic tape protection before installing the cartridge? Check to see if there is anything on the bottom of the unit. It could be the problem. Check the install instructions.
Feb 01, 2010 | HP PSC 750 All-In-One InkJet Printer
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Scanner
yes! you can scan the image to the computer. the printer may not like it w/o the ink.
leave the empty ink cartridge in the printer.
Nov 07, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
507 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
