Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Leaking toilet we purchased a saniflo toilet and installed it in a basement bathroom, (new construction). It seems to be working fine we have been using it for 3 weeks and just now noticed leaking coming from the bottom (base) of the toilet. We checked the toilet for cracks and tested it with water and their were no cracks. any thoughts. It is installed on a cement floor.
  • rkorby Dec 22, 2008
    I bought saniflo compact toliet and installed it on a ceramic floor. It flushed and no leaks until left alone for a few minutes then I noticed standing water on the floor. Flushed it again and checked for leaks and all fitings are tight. Anybody know the cause of this?
  • lesoleil70 Jan 03, 2009
    Hi, I have the exact same problem with a saniflow XR pro, no apparent leaks from tank or anywhere, just after you fluch, a few mins or hours later a thimble full of water appears from the bottom of the mascerator unit, can anyone help?
    Genius:
  • 1,605 Answers
Check the seal between the tank and the toilet.tighten it as necessary. (not to tight! you will crack the ceramic). Mkae sure the tank is square to the toilet.
also the water inlet connector.
Posted on Nov 24, 2008
This is a most likely caused by the toilet not being mounted properly. First, turn off the water supply. Next flush the toilet. Then, take a shop vac and remove excess water from both tank and bowl. Once that is done, disconnect tat supply line going to the toilet. Disconnect where the supply line connects to the tank. Finally, take the nuts off of the Johnny bolts. These are the bolts that hold the bowl to the floor.
Then remove the toilet and scrape off the excess wax from both the bottom of the tank and also the flange on the floor. Next, you'll need a new wax rings and possibly some new Johnny bolts. These can be bought at a local hardware store for under $10 total. Sometimes you'll need to put the new Johnny bolts in because when the last ones were cut off to get the egg caps on, the threading would get screwed up.
Now, take the wax ring out, place it over the flange so you can see down the sewer pipe. Put the new Johnny bolts in on each side of the flange. Center them so that they'll line up with the holes in the toilet bowl. Lift the toilet up, and set it down squarely on the flange, making sure that the Johnny bolts went through properly. Sit down and rock the toilet down on the wax ring til the wax has done its job and the toilet sits firm. Put the washers over the Johnny bolts, with the lip up so that the egg caps pop on when you're done. Next, put the metal washers down over the Johnny bolts. Then screw the nuts on until it's firmly in place. Don't screw too tight or you'll break the bowl. Now, take a Sawz-all or just a hacksaw blad and chop the Johnny bolts off so that you can put the egg caps on. Then hook up the supply line, and turn the water back on. This should fix your problem.
Posted on Jan 04, 2009
Why does it leak from the top outlet?
  1. SANIFLO upflush toilet - YouTube
    ? 6:14
    www.youtube.com/watch?v=-F1v6GIbWF8
    Aug 10, 2011 - Uploaded by Regis Saragosti
    Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
Jul 10, 2015 | Saniflo Plumbing
We have a basement bathroom. The bath drains away very slowly, but everything else seems fine - toilet and sink draining/flushing fine. Can we use a usual unblocker (eg sodium hydorchloride) to unblock?
I worked on a lot of Saniflo products, they do not recommend using any products that have bleach or chlorine. Make sure the flapper inside the side inlet where the bath drains, is not obstructed.
Dec 03, 2012 | Saniflo & Saniplus& Macerator Pump
My basement toilet pump runs constantly I have unplugged it till I contact a plummer; can i still use my two upstairs bathrooms in other words does any of the sewage up stairs flow through that bathroom...
Yes! If the system you are talking about has a tank behind the toilet, that tank only pumps out for that bathroom group. It pumps out with a 2" line into the existing gravity system. Your other batrooms are on that gravity system so you would be fine to use them. The only way there would be a problem is if the main sewer line out of the house is backed up. But you would be having problems if that were so (possibly the washing machine connection in the basement would be overflowing. Sound like the pump float in the small tank behind the toilet is hung up on somthing not allowing it to shut off. No need to get a plumber for that. Just remove the top of the small box and see why the float off of the pump is not shutting off. If has been installed for awhile (a few years) possibly the float contact could be gone and in that case a plumber would be the best bet to get a part needed. But save some $ and see if it is hung up on somthing (dried toilet paper) and clean it off and see if the pump stops when plugged in. If so you just fixed it yourself. If not then call the plumber. I'm a licensed plumber so I have a bit of background here.
Sep 27, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Do the saniflow toilet need to be plumbed in to mains waste? I have a patient who needs a toilet located outside the house that needs to be trouble free
Hi and welcome to FixYa, I am Kelly.
In short yes it will need plumbed with a smaller drain line to the home waste drain.
The unit uses a fast-rotating blade to reduce waste and toilet paper in the flush water, which is immediately and entirely released under pressure through "small-diameter piping" to the sewer or septic tank. No special maintenance is needed and the pump is sealed for life. This simple and cost-effective alternative to conventional plumbing is ideal for basement renovations and other home-improvement projects. Properly sized, a Saniflo macerating system can handle all the fixtures in a bathroom, including the sink, shower, tub and toilet & endash; even on a septic system. What's more, these fixtures will work up to 12 feet below and as far as 150 feet away from a septic tank or sewer line.
Go to this page and download the manual for the installation instructions:
http://www.saniflo.com/Downloads.aspx
These are all the installation downloads available on that page:
Installation Instructions:
SANIBEST SANIGRIND SANIPLUS SANICOMPACT SANIPACK SANIALARM SANISHOWER SANISWIFT SANIVITE SANICUBIC Classic SANISTAR SANITOP
Thanks for using FixYa,
Kelly
Jun 01, 2010 | Home
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Thinking about installing basement Saniflo toilet
Zoeller makes the best unit out there do you research first
Nov 15, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo ejector experiencing shaking when flushed
I have included the installation instructions. It also includes an expanded veiw of the toilet. The troubleshooting area can give you ideas. From what I read, it is possible that something has feel into the grill. Hopefully this helps.
http://www.saniflo.com/pdf/install/PLUS_US.pdf
Apr 18, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Basement up flush toilet systems
sorry Fran,that is what they run.thats just for the unit don't forget install cost too.good luck with this project.
Mar 29, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
706 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
