Question about LG GCC 4320B CD-RW/DVD-ROM Burner
Reads all but DVD-Help PLEASE
My dvd-rom/cd-RW (combo) drive wont read ANY DVD that i insert, he did that after a week i got it, but he failed to read the dvd and i just inserted the disk again and again intilll it recognize it but now he doesn´t even stop spinning it last 2 or so minutes to stop and it the dvd wont appear, the dire burns and read very good all kind of cds but not dvd, PLEASE help me im desperate
  • 6 more comments
  • Robert Peralta Jan 01, 2007
    as i said before it wont read any kind of dvd and i have the programs i need to play movi e dvd i know alot about compuuters so dont go with the basic it jus doesn´t recognize the dvd and its not on automatic play and i have already tried with it im interesed right now to play a data disk and is really urgent i have a lot of dvd movies around that i cant read either
    i have Windows XP media center edition and it doesnt appear any error message
  • Robert Peralta Jan 02, 2007
    i cant make a test cause i have to wait till it stops spinning and when it stops it i´ll freezee like not responding (the software) i have already tried it, and i wouldn´t say progresesively cause it reads but whenerever he feels like iit and he has been sleeping for a long time now >_>
  • jaec Mar 03, 2008
    Dear Sir
    I have a External DVD writer LG does not read any DVD ,but no problem with CDs,I have downloaded a new version of frimware,but the problem still the same.
    Rashid Safieh
  • Anonymous Feb 12, 2009
    LG GCC 4320B CD-RW/DVD-ROM won't read DVDs
  • Anonymous Feb 16, 2009
    It just won't read DVD's, no problem with CD's or music CD's who can tell me how to fix this?????
  • Anonymous Feb 17, 2009
    i have a same problem :(
  • dogdad2006 Apr 06, 2009
    my cd/dvd [player will read and play cds but not dvds.
  • 624 Answers
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Posted on Jan 01, 2007
  • tomj23 Jan 02, 2007
    You didn?t indicate your experience level or a detailed listing of what you had tested so the basics are where you generally start. I?ll now assume that you?ve already been through the basics such as making sure you can read these DVDs on another machine, cleaning the drives read/write heads and checked the Windows device manager to ensure everything there is OK.
    If the drive reads and writes CDs, used to read DVDs but got progressively worse as time went on then you may simply have a drive with defective read heads, not much you can do to fix them if that is the case. Here is a link to a free-ware program written by Nero you can use to test several major functions of your drive:http://www.onlinedown.com/detail/1245.ht... There isn?t much documentation, however, you download the file, decompress it, start the program and insert a DVD data disk in your R/W drive. Click on Run test in the upper left hand corner of the program screen, select run all tests and you?re running.
  • tomj23 Jan 19, 2007
    To be honest from what you?ve described it sounds like you drive probably has a physical problem. Considering that a new one would run (starting at $40) and how much time you?ve spent I would probably just replace it after checking the drive cables and connections (just to make sure).
    If you play a lot of DVDs you might consider buying an inexpensive DVD/CD-ROM just to play and a separate CD/DVD-R/W to do recording. I generally split the functions between two drives to speed copying and to save wear and tear on the more expensive writer.
    As far as LG goes I?m indifferent to the brand but my daughter won?t touch their electronics either.
Teac Dw 224E-R WONT BURN ON A DVD - Is it a DVD Writer?
hi no its only a CD RW, and not a CD/DVD-RW its just a CD writer and a dvd( rom )..read only memory which means it only reads dvd's but does not write them...hope this helps
Jun 14, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
CD-RW/DVD ROM Combo
no you want a dvdrw or dvd burner
combo only burns cd's and reads dvd's(not write/burn)
Jan 05, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Dvd drive not reading properly
Have you loaded the dvd drivers to view the dvd's through ? you need something like Cyberlink or Power DVD
Dec 25, 2008 | Medion (40002895) CD-RW/DVD-ROM (Combo)...
My Lite-On combo sohc-5236v does not read CD but it reads DVD.
The reason for this is most likely Copyright protection. If this is the case, it will read DVDs as it is only a DVD-ROM, but what happens in the case of CDs, is that they recognise the drive as a Burner, and the Copyright that is embedded into the CD wont let the drive read it. This also happens with DVDs in some DVD burners.
The way to test this, is by getting a CD-RW disc that has music or files on it, put it in the drive, and see if it reads it. If it doesn't, then you may have a fault with the drive, but if it does read the CD-RW, then the only way round it that I know of, is to buy a CD-ROM drive and use both drives.
Dec 05, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
My cd/dvd rom no longer reads or burns
The laser that reads (or "burns") has failed.
Spend $30 to buy a new CD/DVD reader/writer.
Nov 16, 2008 | Compaq Refurbished 7 EVO N410C DVD/CD-RW...
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Not reading dvd combo drive
HL-DT-ST RW/DVD GCC-4522B
h!, above is the model type of my combo drive dvd. It does not work anymore, it only reads a cd format but not dvd..can you pls help me with this..my personal email address hpbirco@yahoo.com pls send me ur answer to my problem..tnx
Sep 03, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
LG GCC 4320B CD-RW/DVD-ROM Burner Logo
441 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
