Question about Minolta EP4000/5000 CS/PRO Copier
Minolta cspro 2080 having black copies - Minolta EP4000/5000 CS/PRO Copier
    Problem Solver:
  • 3 Answers
Chek the scaner lamp(upper lamp ) if its working during copy other ways u have to take up the lamp and check it by oem meter , u have to check also the thermal fuse for that lamp on the same unit. I hope that will solve ur problem ,if not high voltage unit above the drume is damaged.
Posted on Nov 26, 2008
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
Minolta cspro 1083 makes gray copy
has the developer been replaced and the required F8 run along with the drum counter reset. Also was the F5 run and F3 all of these F# are run in service mode.
Nov 13, 2012 | Minolta EP1083 CS/PRO Copier
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
I just bought a used EP 2030 CSPRO for my personal Classroom use but when I try to copy it only gives out all black copies. Any idea? Thanks Byron Cowan
Try to copy with the glass cover open, once the scanner moves you should see that the halogen lamp is lighted. If not, either the lamp or the thermal fuse is busted.
Oct 12, 2009 | Minolta Office Equipment & Supplies
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
321 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
