Question about Vicks Ultrasonic V5100 Humidifier
Vicks V5100 does not produce mist, after being stored for 1 year.
I bought it last year, but used it no more than 4 times and stop it because it was inundating the room of white dust. When I tried to use it after about a year, it produced very little mist for a few hours and then, stopped. I can feel a little air flow only, but no mist at all. I cleaned the filter and all the parts, but it still doesn't work. I have another one at the office bought almost at the same time, and this one is working after a year of being stored.
Is there any warranty in place? Is it repairable? Thank you.
  • Anonymous Nov 25, 2008
    dose not produce mist
  • Anonymous Nov 29, 2008
    Same problem. It made horrible noise after one year for couple of days. One day the noise was gone I thought great, problem solved automatically but the case was different. I see only yhe bubles coming out no mist.
5 Suggested Answers
fwadley
  • 482 Answers
SOURCE: mold in vicks cool mist vaporizer
if you can take it out side and plug it in, put some bleach in it and let it run for a few minutes. then wash it out and run the rest of it out.
Posted on Dec 16, 2007
JohnSc
  • 21 Answers
SOURCE: Odor
First, clean or replace the filter. Next, mix a very weak solution (40:1 ratio) of bleach and water to fill the unit. the bleach will kill any bacteria that could be causing the odor, but NOT harm anyone, The filter will take care of any hard water issues. Just don't make the mistake of thinking "If a weak solution is good, a strong one is better". NOT TRUE. Stay with the 40:1 mix unless you like breathing bleach. (Yuk) Note: It may take a couple of days for the odor to go away.
Posted on Feb 08, 2008
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
  • 139 Answers
SOURCE: Produces a ton of white dust... Why???
Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
Posted on Feb 29, 2008
SOURCE: Vicks caporiser is spitting water instead of steam
Have you cleaned it recently? Sometimes that's an indicator that it needs to be cleaned.
Posted on Oct 29, 2008
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Vicks warm air humidifier replacement part
Does this help you? http://www.appliancefactoryparts.com/humidifiers/vicks/v5100ns.html
My OX husband trod upon his new humidifier LOL...broke the tank and I cannot stop leaking. Anyone have a site where I can buy just a Vicks tank?
Feb 18, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
I do not see visible vapor
Apperently, it doesn't produce mist.
From the product page "Provides invisible cool mist for easier breathing with 20 percent quieter operation".
Jan 11, 2011 | Vicks Cool Mist V3500 Humidifier
The water doesn't seem to be passing through the filter, therefore the bottom reservoir isn't filling up enough to create mist
If water won't pass through the filter, then either the filter has an adjuster that needs to be opened up or the filter needs to be replaced.
Nov 11, 2010 | Vicks Ultrasonic V5100 Humidifier
Hi, We just purchased a vicks warm mist humidifier. We used it for two nights in my daughter's bedroom...we then noticed a sticky residue over sections of the wall as well as crackling paint? Is this...
is it possible that you have the mist turned up too high? If the room is very small, the high setting could be providing too much humidity to the room. I'm thinking that the paint crackled as the humidity climbed.
Nov 04, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
For a vicks warm mist humidafier can you use the vaposteam liquid everyday
i cant see why not. just make sure you have good ventilation to prevent mildew or mold growth
Nov 11, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
Odor
Feb 08, 2008 | Vicks Ultrasonic V5100 Humidifier
Vicks Ultrasonic V5100 Humidifier Logo
Top Vicks Humidifiers Experts
Raygin
Raygin
paulcarew
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
