Question about Dacor Prefrence PRV36 Stainless Steel Kitchen Hood
DACOR DOWNDRAFT RV36B PROBLEM
The vent is stuck in the up position an the lights are all on it will not reset. After a while 2 lights go off leaving only the hi and low lights lit. Tried killing the power no change.
  • 175 Answers
When just the high and low lights are lit, the unit is in childproof mode. try holding down the high and low buttons at the same time until they go out. then if they do, check the response of the other buttons. If this dosen't help, there are really only 2 other options. Most often we see the control board go bad on these (located behind an access panel in the lower right hand corner of the unit below the counter) or the button pad contacts wear out. If the only button that doesn't respond is the up down button, and all the other buttons work fairly easily once its up..then you probably have a bad button pad. If the thing does all sorts of weird things and seem to have a mind of its own, probably a bad control board. the control boards on these fail so often, they re-designed the board to prevent further failures. The button pad is easier to replace and cheaper, so if you have to guess go with that first. good luck!
Posted on Jan 13, 2007
  • Harold Shapiro Sep 24, 2011
    I have a similar problem. Do you know the correct part number that I need to use when ordering a replacement control board for the Dacor RV36?
  • 3 Answers
The control is in the secure mode press the 2 buttons that are lit for one second to reset the control
Posted on Jan 17, 2009
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
I have a Dacor downdraft vent RVxx. I find that 2
I just unplugged it again and replugged it. Now it works. Thanks! Renee
Jun 13, 2009 | Dacor Preference RV36 Kitchen Hood
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
YOU WILL NEED TO CONTACT A AUTHORIZED DACOR DEALER OR PARTS DISTRIBUTOR I SUGGEST CALLING FOX APPLIANCE IN ATLANTA GA OR THE MFG IN BERKLEY ,CA
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 26, 2008 | Kitchen Ranges
Call Dacor at 800 793 0093. They'll tell you who has the part.
Dec 03, 2007 | Dacor RV36SS Kitchen Hood
How to replace up/down switch in downdraft vent for cooktop
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Jul 27, 2007 | GE Profile JVB67H Kitchen Hood
Kitchen Ranges Logo
1,769 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
