Question about Dayton G73 Utility Heater
Hooking up my heater
I have a dayton g74 utility heater, how do you hook it up. i have it hooked up using black on li & red on l2 where does the white wire go.this is a 208 volt heater.
  • IDOTMAN Dec 15, 2008
    I have the same problem. The heater (G73) is 220 and I have 4 wires running from the box to the heater. The Black connects to L1 and the Red to L2. I have a white and a bare copper left. Do they both connect to the Green ground Screw or do I not connect the Bare copper to anything?
    Problem Solver:
  • 15 Answers
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Posted on Dec 03, 2008
The black goes to L1, Red to L2. The bare copper wire is the ground which goes to the grounding nut in the rear, it has the green washer on it. The white is the 'common' or 'neutral' wire and isnt used, it gets capped with a wire nut and some electrical tape.
Posted on Mar 10, 2009
Wireingpowerin3e841
In the electrical makeup box will be a black, white and green wire...
hook the black to the black in, the white to the white in, and the green to the green or bare wire in...
heatman101
Oct 25, 2010 | Dayton (3E380) Gas Heater
Original AC Condenser fan motor had three wires L1 L2 & Fan Capacitor The replacement Dayton motor has 4 wires, L1 L2 & 2 capacitor wires solid tan and tan with white tracer One goes to the F...
Yes, that can be confusing...hook the tan wire with the white strip onto the same line wire as the one going to the capacitor...usually the L2 wire....so then in reality you have the two tan wires hooked onto the common and the F terminals of the cap...
heatman101
Aug 15, 2010 | GE Heating & Cooling
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Trying to install used Dayton 3E367C garage furnace. Wondering if anyone has a wire diagram or can explain colored wires. Thanks for the help. Wayne
in or on the heater there should be terminals labelled R, W1, W2 if its a 2 stage and G for fan only operation hook up any color of wires as long as the W on the stat is hooked up with W on the heater and so forth but for heat only operation utilize the R and W terminals only.
Jan 24, 2010 | Dayton (3E379) Heater
I just purchased an used furnace model # 4E458 and serial # Q9541564. I am trying to find a wiring diagrahm. Where can I get one? Thank you Joe Biernasz
if you go to the manufacturers web site they should be able to help. but most of the time you just need to hook up your high voltage(120v) which if your black, white and green. and on your low voltage side it is usually red=r,green=g,yellow=y and w=white. if you have a thermostat that is battery operated than you do not need a common wire. if you need a common wire than us the blue wire. and if you are hooking up an a/c system then hook up 1 wire to y and the other to common
Nov 10, 2009 | Dayton Gas Furnace Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Installing a Dayton G73
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dayton G73 Utility Heater Logo
448 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
