Question about Dell Inspiron 6000 Notebook
Inspiron 1720 backlight not working after standby
I turned my system on to standby and there was a brief blink (a greyish screen) and then when i came back out of standby the backlight was gone. could still see desktop, but barely. tried re-installing drivers and fixing them. this happened last week too but somehow it just started working again. any help would be great
inspiron 1720 - or uninspiron as im going to coin it
  • 61 Answers
Try it in safemode and chk if it works its drivers issue or try to load bios and see if you get the same problem if it is then it is the problem with you LCD screen
Posted on Nov 25, 2008
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Dell inspiron 1720 keeps dropping into standby mode when running any application using windows XP
Make use of some antivirus! Or it may because that your internal memory is full...
Jan 29, 2012 | Dell Inspiron 1720 PC Notebook
My audio effects dont change my voice on my inspiron 1720 series
do a system restore from the time when everything was working fine.
start>programs>accessories>system tools>system restore
download and install dell quickset and flash bios from the support site.
Apr 02, 2010 | Dell Inspiron 1720 PC Notebook
There is a shadow on the left side of the screen of my 1720 inspiron monitor which makes it hard to view
Please check if you see the shadow in BIOS. To go to BIOS, restart your system and start tapping the F2 keys. If you see the shadow in BIOS, then you can contact Dell to get your LCD replaced if your system is still under warranty .
Oct 18, 2009 | Dell Inspiron 1720 PC Notebook
Back light fine with power supply and goes off on battery.
I would need to know what operating system you are running because Vista has a setting for the display brightness when running on batteries. I would suspect that, that setting is turned down to conserve battery power. If this is not the case, then the battery may be too weak to put out the correct voltage requirements for the display. If you have Vista, go to the control panel > power options > In the left pane, look for the display brightness > here you can change the brightness for running on battery and for AC power.
Oct 14, 2009 | Dell Inspiron 1720 Notebook
I have a dell Inspiron 1720. When I boot up it
Replacing the display should solve it.Maybe the inverter but most likely its the display itself.
Oct 04, 2009 | Microsoft Inspiron Notebook
I get a black screen with the mouse everytime i boot to windows
Is it black all the time? From when you start your computer to when you turn it off?
Sounds like the backlight is bad.
Aug 07, 2009 | Dell Inspiron 1720 17" Widescreen...
Laptop screen stays blank at bootup
First try holding down the insert key while booting. Next either your F1 or F2 key will get you into bios.
Try pressing those keys alternately while booting to enter setup. If you get to bios follow the previous poster's advice.
Try re seating the ram boards and the hard drive. Make sure you don't have any usb flash drives installed.
Jun 02, 2009 | Dell Inspiron 1720 PC Notebook
Red standby light light blinking
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Dec 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dell Inspiron 6000 Notebook Logo
476 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
