Question about Logitech NASCAR Racing (963339) Wheel And Pedals Set
Veers to the left
My wheel , when i am on the track will be ok , then to all of a sudden it will go to the left, when i check the calibration it shows that the wheel is set to the left. it does in in Gt Legends and gtr 2. Then i will re calibrate it and it does the same thing. some times it works ok but most of the time it veers to the left. i have recalibrated it about 10 times with no success. i have tried everything, please help me.
SOURCE: G25 Wheel No Longer Responsive
I have this problem and i emailed logitech, they told me to send the wheel back to the dealer for a replacement :(
Posted on Sep 19, 2007
SOURCE: Re: Logitech GT Force Wheel
I don't know what is is yet but i know my power supply is working (~13V) and the power is making it to the board inside the unit, so its internal.
Posted on Sep 06, 2008
SOURCE: G25 wheel not responding
Hey! I had a similar problem! Only the weel tried to calibrate itself, but itjust "twitched"
So I tried replacing the power cord with a similar one from an older wheel. Didn't work for me.
I opened it up and voilá, same problem as "epicname"! I tightened the screws on the optical sensor and put it back together. Now it works like a treat! So i guess if it's the power cord it won't react, If it's the optical sensor it will twitch, notice it doesn't get a signal and give up from there.
I don't know if this will really help anyone, as they would just send it back to the shop and get it fixed for free. But couldn't find the reciept, and often find it's better to fix things myself than to let the local shop send it to their usual place.
THIS IS JUST A LAST RESORT!! ALWAYS TRY TO GET THE WHEEL REPLACED OR FIXED PROFESSIONALLY!!!
Remove all the screws underneath, even the larger black ones. Remove the steering wheel by unscrewing the bolts on the front panel and the three larger screws under the little circuit board in the wheelhub.
Remove the bonnet. theres a black box on the left engine wich contain the sensor. If it's loose you're able to rattle it. If you're not, the sensor is most likely not the problem.
Unscrew the mainboard and remove the bracket it sits on.
Now the Force Feedback rig should be loose.
Flip it over and pop off the little black cap on the sensor(it's just pushed on)
Put some locktite on and fasten the two screws that hold the sensor mount (unscrew and remove the sensor board so you can get to the last screw)
Put everything back together.
Posted on Nov 28, 2008
SOURCE: Unplugged my Extreme 3d Pro/When plugged back in, can't calibrate
I opened my stick and detached the Y controller (little black thing attacthed to left bottem of base) opened him (not braking it) cleaned it whit Q20 and cloth. Assemble again and tested before fastening the screws again.
It works better than the day i bought it now.
Posted on Mar 11, 2009
  • 6 Answers
SOURCE: I have a new G25 Wheel and everything checks out
Do you have logitechs gaming software installed ?
http://www.wingmanteam.com/ for latest release
Post if that doesnt fix the problem
Posted on Jul 11, 2009
How to enter into calibration mode for treadmill Freespirit model 122 30521..
Of you wish to get some details about treadmill repair service mode and calibration then check the following link
http://electro-medical.blogspot.com/
Jan 15, 2016 | Nautilus Exercise & Fitness
Steering veers to left-tires look ok
yes, something has happened to cause this to happen, take it to an alignment shop and they will inspect it and let you know what is needed
Jan 29, 2014 | 2006 Scion xB
2000 ford windstar steering wheel shakes horribly and I let go of wheel veers to the right
These are two seperate problems. The veering to the left is your alignment. This is cheap, about 80 bucks at sears. The shaking is usually ur transmission or tcs
May 03, 2013 | Cars & Trucks
I have a 2003 F350 Super Duty Turbodiesel and the steering is acting weird. It jerks suddenly at times to the right or left when driving at city speeds.
I would check your track bar bushings. If they are worn it will let the front axle shift from left to right. You will usually feel this as the wheel is almost back to center and it will feel worse on a long sweeping turn where the sudden shift will feel more pronounced.
Apr 15, 2012 | Ford F-350 Cars & Trucks
Steering problems with Mercedes ML 63 Amg
you need to get it repaired by a professional alignment shop before you kill someone or yourself
Oct 28, 2017 | Cars & Trucks
This ZR4625 is new. It will not track straight. With both levers forward it tracks to the left, I can pull back on the right lever and it tracks ok but it slows down a little. What do you adjust?
First check both rear tyre pressures, if ok you need to adjust the rod that runs between the left lever and the hydrostatic drive on the left rear wheel so that the short lever on the hydrostatic drive travels further when push the drive lever forward. Regards Phil
Apr 14, 2011 | Husqvarna Zero Turn Mower Z5426
Steering veers to the left?
Drive slowly down the middle of a straight road, let the steering wheel go and apply the brakes. If the car wants to turn by itself check your ball joints and shocks. If the car remains straight you may have an irregular wearing tire which causes it wonder at higher speeds.
I hope this helps
Sam
May 13, 2009 | Hyundai Elantra Cars & Trucks
Sterring veers hard to right
have you tryed to rotate the two front tires side to side to see if the pull goes to the other side ?
Mar 29, 2009 | 2001 Dodge Ram 2500 Truck
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
Logitech NASCAR Racing (963339) Wheel And Pedals Set Logo
37 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Alun Cox
Argospete
Argospete
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
