Question about Ricoh 3310LE Plain Paper Laser Fax
Communication Problem Ricoh 3810 - states "communication problem" when receiving faxes from Buffalo and even one here in Memphis. The repair person stated it was a "carrier" problem. We found an old Brother fax and hooked it up and it communciates just fine with everyone. Can you tell me what the problem is with the Ricoh. Thanks.
  • Dixie Drawl Nov 25, 2008
    Thanks so much. I'll have Ricoh fix it. Interesting that the repair guy didn't even suggest that!!
  • 2,120 Answers
Ricoh's are the ONLY fax machines that i've seen having bad modems. It's possible that it is bad.
Posted on Nov 25, 2008
Please help me with ricoh sc 681-07 on mp 3003
Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
D RFI Communication error
Communication error occurs when the RFID starts to communicate with the RFID receiver.
Retry of RFID communication fails three times after the machine has detected the RFID communication error.
Defective RFID reader and writer
Disconnected ASAP I / F
No memory chip on the toner cartridge
Replace the RFID controller board.
Replace the toner cartridge.
Still, have issues please call me at 1800-204-4427 toll-free.
Aug 29, 2017 | Ricoh Office Equipment & Supplies
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
We are unable to send or receive faxes from specific vendors. Why will faxes go through for one person but then give us a "communication error" for others?
Speed all about speed and noise on the line, on some of my accounts I "de-tune" my unit to communicate with the "problem" units and sometimes I will turn the ECM off. -Carl
Jun 10, 2010 | HP 1040 Plain Paper Inkjet Fax
No communication between faxes.
settings are wrong also check lines to device
May 01, 2010 | HP LaserJet 3050 All-In-One Printer
Continual communication errors with Aficio
Turn on or off your error correction to see if it changes also try changing your phone cord.
Mar 23, 2010 | Office Equipment & Supplies
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Disabling Auto-Print of Communication Result Report
It's in the "user parameters" in the "fax features" menu. No disrespect, but it's a needlessly complicated setting (all of the parameter settings are if you aren't familiar with Ricoh).
You can download the manual here if you don't have one (It's in the Printer /Scanner reference). Look in the index under "Communication result report".......good luck:
Mar 11, 2009 | Ricoh Aficio MP1600SPF Copier
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh 3310LE Plain Paper Laser Fax Logo
175 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
