Question about IBM ThinkPad T30 2366 Notebook
Error code 176 appears at boot up
T-30 error code 176 appeares at boot up
  • 2 more comments
  • mdurain Nov 27, 2008
    no i can not get pasted the error code,so if someone has a way to by pass this problem/reset my thinkpad T30 please let me know.
  • danni_boo Feb 14, 2009
    The problem I am having with my computer is i am unable to sign in my computer
  • pepsson Mar 05, 2009
    Yes I Have the same problem, but my repair person said that he could not fix this problem that easy, so what do I need to do???
    Help me
    bbbbbbbbbbbbbbbbb
    Sniper:
  • 51 Answers
Have you set a password in the BIOS, this is usally a tampering error code
Posted on Nov 25, 2008
Error code ch62 appears on the controller. We have canged th inverter boards and all other P.c. boards yet the error code sill appears
Inverter over 85°C. Check air flow across heat sink, check inverter tight to heat sink use thermal paste.
Jan 12, 2011 | Heating & Cooling
What does error code f24 mean
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport ht washer error code f-24 inop
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error F24
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#@
Jul 03, 2010 | Kenmore HE2 Plus Front Load Washer
F-24 code????
This advice is for Whirlpool and Kenmore model FRONT LOADERS displaying the “F24” Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
(tip courtesy JSROCK)
May 22, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f-24
May 09, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f24
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Nov 22, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet washer stops and has error codes F-24 can cancel and restart but it keeps happning
Jul 31, 2009 | Whirlpool WFW9200S Front Load Washer
Fault code F24
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F24
Aug 12, 2008 | Kenmore 46462 Front Load Washer
IBM ThinkPad T30 2366 Notebook Logo
471 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
