Question about Epson Office Equipment & Supplies
Epson Stylist Photo 1280 - loaded ink as normal, then printer would not print only spits out blank pages
  • Anonymous Mar 12, 2014
    epson Stylist 515 faded pages
I went to Epson's site. Got results I needed.
Posted on Nov 25, 2008
My epson stylus 1280 printer is printing blank pages
If NO print pattern then the Printer heads clogged or damaged. New printer is cheaper than fixing.
Mar 23, 2014 | Epson Stylus Photo 1280 InkJet Printer
Epson Photo Stylus 1280 print heads do not work
The problem is the print head, The ink cartrige for this printer is just a little bottle of ink. What really causes problem in it IS THE CLOGGED HEAD. If you have skill to reach thepen of the head (part that touchs the paper) use a quill tip or rag soak on water and clean it. Or go to EPSON SITE AND ORDER A HEAD CLEANNER FLUID TO POUR INSIDE THE HEAD AND CLEAN IT.
Oct 23, 2012 | Epson Stylus Photo 1280 InkJet Printer
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Yellow lines appear in printed outputs on my Epson 1280. Printer was inactive for about 5 months. ....have cleaned and soaked print head several times. Lines are less intense, but still there. Thanks...
There are two possible causes: 1. The ink dries on the plate around the head output (sprayer), 2. Thin coatings of yellow head broken. The first possibility can be tested by printing blank pages (or just containsthe line - full pages). If after about 50 pages to print, yellow lines had been lost, then the printer is ready for use again. But if not, then thesecond possibility happens. At the output of the head there is a thincoating. If until the coating is breached, then the ink will drip continues,although there is no voltage or current that supplies the headmicropiezzo.
Jul 12, 2011 | Epson Stylus Photo 1280 InkJet Printer
I'm trying to resurrect an old Epson 1280 Photo Stylus. I've changed ink cartridges, and run the head cleaning/nozzle check utility numerous times, but nothing prints out on any test pages, nor on any...
It's time to "cut your losses"; either the electronics that tells the inkjets when to shoot ink is screwy, or the inkjets are totally plugged, despite the "cleaning" cycles.
Responsibly recycle the printer, and buy a new printer.
Maybe, try to find another Epson that accepts the same ink-cartridges that you recently inserted into the old printer.
Nov 19, 2009 | Epson Stylus Photo 1280 InkJet Printer
I installed new printer cartridges and then cleaned the print heads as instructed in the owner's manual. The printer won't print, just spits out blank pages.
Open printer case. Pull out the outlet pipe of head cleaning. Do head clenaing procedure. Is there ink out from outlet? If yes, so head is not clog. If it's still nothing at output, problem with board or short circuit at head. It's hard to repair.
Jul 16, 2009 | Epson Stylus Photo R220 InkJet Printer
I need a repair service for EPSON stylus photo 1280 The paper intake it broken. Prints feed through crooked. Also, new ink cartridges print extremely off colors.
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Apr 30, 2009 | Epson Stylus Photo 1280 InkJet Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
