Question about Sony Ericsson P1i
P1 backup issue
Have a p1 for a year now,works more or less fine, except for the back up process. when connected to the computer the first few back-ups worked ok, since a few months now the phone stops the process, leaving the thing uncompleted.
had the same issue with my m600i earlier, in fact that was the reason to get the p1, seems time to get rid of it, or any solution?
  • smiliemotor Nov 26, 2008
    :-( tried that, no help,- thnx.
I had the same problem until I discovered that if I skiped the third party applications in my back up it went just fine.
Posted on Nov 26, 2008
I am having an issue with my Latitude E6520 keyboard. It has happened a few times since I got the laptop (about two years ago) but has become worse lately. The keyboard will be working fine for several...
The honest truth is its probably just going bad. If you've had that computer for years now the connections may just be wearing out. Especially If it has been under heavy use. There a couple things to check. Such as updated keyboard drivers and other software updates. But its most likely at this point a hardware issue. I would look into upgrading to new computer.
Apr 26, 2017 | Dell Latitude E6520 Notebook
Nothing works on control panel except control locked sensor light. The buttons were working fine then I went to add more drying time and the buttons do not light up or work.
From the details of your symptom you're indicating a possible intermittent loose connection between the user interface (touch panel) and the machine control board or the voltage supply to machine control board at P1 connector.
Disconnect the power cord from the power source.
  • Disconnect P3 and P4 connectors from the machine control board and then reconnect them.
  • Disconnect P1 connector and then reinstall the P1 connector and then recheck operation.
If the wires are good then you will need to replace the control board on your unit.
Here is a link to the part.
Jan 09, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
My Western digital My Book WD5000F032 has been working fine for years. I shut it down and disconnected it one day and now it wont connect to the computer again...I have tried two other computers with now...
The sweeping noise usually means the drive cannot read the first few cylinders and can't finish starting up.
This can be due to drop damage causing an impact on the pallets, a failing head on the drive, a failed pre-amp on the arm or even a few circuits on the PCB board that are involved in the process.
Generally this type of failure would require the help of a pro to recover files off.
If this is just a backup drive and you have all you original files intact simply replace it and back your files up onto the new one.
If this had important files on it that aren't backed up elsewhere and you need a pro, reply back with your location(Country, State, City) and I will connect you with a nearby pro who can assist you in a lab environment.
Hope this helps FixYa,
Mar 11, 2010 | Computers & Internet
Battery does not get charged fully... and does not support load of computer in backup mode...
If the battery backup unit is over 2.5 years old then you will need to replace the battery. Go to your local electronics parts house or battery distributor. They will have the gel cell battery you need in stock. These units are just like small car batteries, after a few years of use they will break down and not hold a full charge. When this starts to happen the battery life is about to be over, it will hold less and less charge until one day no power at all and then the UPS will not power on. The UPS have a monitor circuit that will prevent them from powering up with a dead or missing battery. The replacement battery should run less than $20.
I hope this helps, if so please rate our solution.
Corporate Computer
Jan 05, 2010 | APC Back-UPS CS 500VA UPS System
Uncaught exception dssma invalid state (5):3
Perform a hard reset of the BlackBerry smartphone.
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If the Problem continues
Perform these Steps:-
Use the following steps to back up a BlackBerry device:
  1. Connect the BlackBerry device to the computer using a USB cable, and open the BlackBerry Desktop Manager.
  2. Ensure that the BlackBerry device is connected correctly. The word Connected should be displayed at the bottom of the BlackBerry Desktop Manager screen.
  3. Double-click on the Backup and Restore icon.
  4. In the Backup and Restore screen, click Backup.
  5. Choose a location where you wish to save your backup file.
  6. Give the backup file a new name or leave the default name in the File Name field.
  7. Click Save.
  8. The BlackBerry device has now been fully backed up.
To delete all data from the BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, click Options.
  2. click Security Options Then Select General Settings.
  3. Click Menu button then Select Wipe Handheld.
  4. you will get message click Continue.
  5. they Type Blackberry, Press Enter.
To Restore the Data to your Blackberry Handheld 1. Connect the BlackBerry device to the computer using a USB cable, and open the BlackBerry Desktop Manager. 2. Ensure that the BlackBerry device is connected correctly. The word Connected should be displayed at the bottom of the BlackBerry Desktop Manager screen. 3. Double-click on the Restore Tab. 4. Navigate to the backup file you want to restore to your BlackBerry smartphone. 5. Double-click the backup (.ipd) file. 6. Restore Process will start.
Aug 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
Got this Bold two days ago & it started yesterday by shutting down & then re starting but showing "uncought exception : java.lang.nullpointer.exception" about 8 times then it stops. Then theres all...
Technically speaking you should just return the phone and get a new one.
If you are feeling adventurous, you can try upgrading/reinstall the software on the device.
Here is the procedure to upgrade the software.
Step #1
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager
Please rate this if it fixes your issue
Jun 03, 2009 | RIM BlackBerry Bold 9000 Smartphone
Car not starting after car runs for a while and weather is hot
have the starter tested because it sounds like a bad solenoid in the starter and it makes it get hot so it won't start
Apr 26, 2009 | 1991 Lincoln Town Car
Shutter guard won't close completely
buy another camera. Nikon sucks in my opinion. 2 years and the same issue.
Feb 01, 2008 | Nikon Coolpix P1 Digital Camera
Sony Ericsson P1i Logo
48 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
