condensor coil is clean;it wasn't, I cleaned it. condensor fan is working freezer condensor is warm and working fridge condensor is not warm and is not working I checked the door switch for the fridge but the condensor did not kick on
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 685/S Stainless Steel
Sub-Zero 685/S Stainless Steel Side by Side Refrigerator
How do you attach a water fileter to a Sub Zero 685? To the large white hose or one of the small...
(More)
How do you attach a water fileter to a Sub Zero 685? To the large white hose or one of the small ones coming out of the blue water controller?
door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is...
(More)
door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is working.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
