Question about Apex Digital GT2015DV 20 in. TV/DVD Combo
TV TURNS ON BUT NO PICTURE
MY TV WILL TURN ON BUT THERE IS NO PICTURE ITS AS IF ITS NO REALLY ON BUT I AM ABLE TO HEAR IT CLICK ON AND IM ABLE TO OPEN AND CLOSE THE DVD PLAYER THIS IS A CHRISTMAS PRESENT SO I WOULD APPRECIATE IT IF SOMEONE COULD GET IN TOUCH WITH ME AS TO HOW TO FIX THE PROBLEM SEEING HOW I DONT HAVE THE MONEY TO GO HAVE IT FIXED THANK YOU VERY MUCH
    Problem Solver:
  • 8 Answers
If your are able to open and close the dvd and able to hear the tv clike it means you secondery power supply is working you have the +5 volt and some other votege
i will look in the hv section and see if you have +120 v
you may have hv short
Posted on Dec 03, 2008
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
My name is Anthony, and i was playin on the ps3nCall of Duty Online, out of nowhere the screen colors change and turn black, im using a mic and i can still hear people talking but my picture is gone. I...
Yes it ur tv.Ur tv LCD inverter backlight board is dead.Change this board to get picture back.It a long board usally.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 14, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My rca
Tac switch defective. (front panel control switcht) replaced it.
Aug 04, 2008 | RCA F27442 27" TV
SANYO avm248 HAS SOUND BUT NO PICTURE
I would check the regulators and horizontal output transistor.
Apr 09, 2008 | Televison & Video
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Apex Digital GT2015DV 20 in. TV/DVD Combo Logo
245 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
