Question about Indesit WA 115 Front Load Washer
This indicates a fault unfortunenately it doesnt say which one the most likely problem will be brushes in your motor
Posted on Jun 25, 2007
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect.
If the
water flows though the inlet then the flow pressure should be good, if not the
inlet valve is bad or there is dirt in the filter. Also check the flow at the
inlet of the water line. Once the water comes into the system the WATER LEVEL
SENSOR - normally a pressure switch- must activate at the preset/chosen level
to give the signal to the program controller to switch on the motor. What is
most important for the motor to start functioning is that the door switch must
be ON when the door is shut or this will be an error for starting the motor for
rinse and wash.
Test a
pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this
link to replace the inlet valve:
Finally
after the wash the drain valve will be activated, the water is allowed to come
in to rinse and then finally the dry spin with the drain valve/pump activated
so as to drain off all the water from the clothes during the spin.
Make sure
that a fault in any of the cycle will relate to the specified action, so check
the command from the program module and then the executing device be it the
valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Feb 12, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Jul 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Jun 27, 2012 | Frigidaire Washing Machines
It is
If the
Check this
Finally
Make sure
Mar 12, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The slow inlet flow and clogged draining can slower the time of the wash and so both the inlet and outlet must be cleaned and flushed.
Aug 09, 2011 | Electrolux Washing Machines
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 22, 2011 | Washing Machines
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.In this case the flow being low it can be fault of the inlet valve or the inlet filter.
Jul 19, 2011 | Tricity Bendix AW1054 Front Load Washer
Jul 13, 2011 | LG WM2701HV Washer
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Mar 23, 2009 | Whirlpool Washing Machines
Jan 23, 2018 | Indesit WA 115 Front Load Washer
Feb 09, 2014 | Indesit WA 115 Front Load Washer
111 people viewed this question
