Question about HP Office Equipment & Supplies
I have a hp.deskjet printer but i cannot get it to print. It has two new ink print cartridges and they are inserted properly,and all the connections are secure.
    Scholar:
  • 162 Answers
Remove tape under the cartridge and reinsert it and turn off it for 2 to 3 minutes after that try to print.
if in case same issue.
uninstall and reinstall printer driver .
It will help you to resolve the issue.
Posted on Nov 24, 2008
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
How do I insert Ink Cartridge into HP Deskjet 1510. Do I need to have 2 cartridges inserted. Only use Black.no other details
Dear
You can follow the link. Yes you do have to install 2 carts. to work the printer. However from printer setting you may disable color print.
Note Ink cart head gets clogged when not used prolonged time.
Thanks. Replacing Cartridge HP Deskjet 1510 All in One Printer
Mar 05, 2015 | HP Deskjet 1510 Allinone Inkjet Printer...
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
Printer will not print,machine says ink cartridges not in place,not so new cartridges in stalled
Good day,
The printer cartridges might not have been installed/inserted properly.
Here is a step by step instruction http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01367400&lc=en&dlc=en&cc=us&product=3390949
Keep me posted!
Jas
Feb 18, 2011 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 648C printer
Just a suggestion: Have you tried using a different ink cartridge? I have found brand new cartridges to be bad right out of the wrapper.
Aug 29, 2008 | HP DeskJet 648c InkJet Printer
Printer not printing
hope you are not properly setup your cartridges
  1. turn off your printer
  2. open your cartridges
  3. setup properly
  4. go to printer properties then if your printer ink show press
  5. test print okkkkk
Mar 05, 2008 | HP DeskJet 930c InkJet Printer
REPLACED INK AND STILL NOT WORKING
Due to shiaty design, it is easy to accidentaly puncture the printed circuit with the sharp end of the retention spring while inserting a new cartridge. Use a flashlight too look at the white/copper sheet the cartridge makes contact with and look for a puncture (probably near the lower right side.)
Mar 15, 2007 | HP Deskjet 6940 InkJet Printer
16 people viewed this question
Ben Johnson
