Question about Zanussi 21 in. DCE5655 Free-standing Dishwasher
It fills up with water and all the lights are going off and starts to pump out the water. Durung the draining all controlls including the on/off button do not work and the door too. It kept repeating it. After some unplugging it from the mains a few times and leaving it off for a while now it just drains/pumps water out and no lights are on at all except the power on light. If the on/off button is off the light is off as well and it keeps pumping out water, the same happens if the door is opened.
  • Anonymous Feb 11, 2009
    I've got the same problem - it wont turn off or respond to any of the buttons but it looks like you've been waiting 2 years for a response so I won't hold out much hope!
There is water in the bottom panel which has activated the float switch which overrides everything to stop the room the dishwasher is in from flooding. Remove the panel look for the leak. In my case one of the pipes had come off. There will be a lot of water in the panel so try and drain it first, tip the washer forward over some sort of container to catch the water. In my case I got very wet.
Posted on Feb 15, 2009
Oven start but trip
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Zanussi 21 in. DCE5655 Free-standing...
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Got a zanussi dishwasher zsf6160, lights working but none of the programmes are starting, not taking in any water?
if you can here the drain pump run at the start the fault is with the water valve or blockage in the side tank on the lh side. if you dont here the drain pump it possibly the heater thats down to earth. the electronics can detact it and not start the prog if heater faulty.
Jul 22, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
HOTPOINT FDW60P DISHWASHER
There is usually a float switch inside the DW body. Usually a polystyrene lump. This may be stuck in the up position, or a pool of water may still exist within the case.
When you say trips the electric - is this your wall MCB or ELCB ? If it is that then there is a major electrical fault on this machine that needs investigation.
Jun 11, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Zanussi dishwasher water input
it is possible but if you use a hot fill you will find that the rinse aid will produce a large amount of foam and the dishes wont dry properly
Dec 22, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi 21 in. DCE5655 Free-standing Dishwasher Logo
348 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
