Question about Tomtom GO 300 GPS Receiver
Tom tom go 300 ''unable to store settings'' ''file access error'
My tomtom keeps coming up with " unable to store settings" "file access error" can anyone help please
  • lmeadm Dec 29, 2008
    OP is describing the exact same problem I'm seeing on my GO 710 - It's never kept my settings since day-1 (ie: Always had to select language, etc. whenever it was powered on) - I assumed this was because I didn't use it much and the battery was being allowed to drain completely. However performing the latest F/W upgrade I now get an actual error on the screen during the power-on preference settings, "Unable to store setings, File access error" (And my selections are still not stored) - I've just got my hands on a 2GB SD card and tried that with the exact same problem (The write-protect on the SD must be off as I performed a Windoze format of the card).
  • Anonymous Feb 21, 2009
    Exactly the same problem with a GO510. Anyone got a fix?
Connect to PC
Find the TomTom using Windows Explorer "drive F:" or "removable disk F:" or similar
Right click
Properties
Tools
Error checking
"automatically fix file system errors"
Start
Ta Da! Well it worked for mine......
Posted on May 08, 2009
    Novelist:
  • 158 Answers
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Posted on Dec 16, 2008
Factory reset gps
UNFREEZE Tom tom sat nav USING WINDOWS OR MAC PC
This will unfreeze your tom tom after exhausting every avenue this works!
You will need Internet access.
Ensure you have the correct tom tom desktop softwear installed on your computer for your tom tom device.
If not then download from tomtom
Removed sim card from tom tom located under sticker lower end of tom tom.
Carried out on a windows laptop with windows 7
(Note this should also work on mac although I did not get to try it and it is stated you will need rosetta on intel macs)
Ensure you download the flash tool for tomtom (clear_flash.dmg) for your operating system windows or for the mac VERY IMPORTANT YOU HAVE THE TOOL DOWNLOADED FIRST.
1.For windows: www.tomtom.com/updates/clear_flash/clear_flash.exe
connect tom tom to computer
find the tom tom on your computer and select all the files
you can firstly copy these to another location or separate drive before deleting all files.
Now delete ALL the tom tom files
Format your tom tom to FAT32 if using windows (im not sure of the mac settings yet)
Keep your tom tom connected to your computer
Run the flash tool and Flash the tom tom memory with the tool.
Restart your tom tom
It will update (but this time it should work!)
Select done after update
Tomtom reboots (restarts)
It may ask you to install a new update but there may not be any update to install just
Select yes to update.
Eject tom tom from your pc by selectinglower right corner symbol.
Now unplug device if ejected correctly
Congratulations your device should now work again.
Note I did not replace my sim card as it is not required to work the gps.
Hope this helped someone.
My device does not keep its settings What should do
Aug 14, 2014 | Tomtom TOM TOM ONE WE V3 GPS Receiver
Unable to update Tom Tom in windows vista keep getting error 1060 any solutions?
perform the following:
type the following three lines in to the Command window:
%SystemDrive%
cd "%ProgramFiles%\TomTom HOME 2"
xulrunner\HOMERuntime.exe -app xul\application.ini
To avoid having to type these lines every time you start HOME:
Right-click your desktop and choose New > Text Document - enter the commands provided above and then save the file as RunTTH.bat
copy this file to the TomTom HOME 2 folder in C:\Program Files (you will require Administrator rights to do this)
in the Start menu, right click on the TomTom HOME 2 icon.
select Properties
in Target, change "C:\Program Files\TomTom HOME 2\TomTomHOME.exe" to "C:\Program Files\TomTom HOME 2\RunTTH.bat”
The icon will change and HOME 2 should now run normally on your PC.
Please note that links like "Send to TomTom device" or "Add to TomTom" won't work because they rely on TomTomHOME.exe (which this workaround by-passes).
A full fix for this error will be implemented in a future HOME update.
NOTE: for 64 bit Vista change the second line of code to:
cd "%ProgramFiles(x86)%\TomTom HOME 2"
Jul 22, 2009 | Tomtom ONE 125 GPS Receiver
TomTom One GPS fault
I had the same problem after downloading the latest maps, the unit was slow to boot up and would not find any satelites. I had no response from e-mails to Tom tom tech support and I was going to give up and buy a new device if this fix failed. I had tried paper clip resets and resetting to factory settings but they had not worked.
After reading the previous answer to this link I searched Tom tom support for 'clear flash' and the search results were more useful than the FAQ on the normal support pages.
I used Tom tom home to uninstall the current software application and then reinstalled the latest version (I had to go through several updates as my version of the software was from when I purchased the unit in 2007), I then downloaded and ran Clear flash and made sure that I disconnected the tom tom from my PC using the correct procedure (using the eject button in the bottom of the tom tom home screen as I read that this could have contributed to the problem in the first place).
After another reset the device came to life and after a few minutes searching for satelites outside the device worked as it should (try checking the configure GPS option if it is taking a while to find a signal, it could be just me but it seems to speed up the search process).
Hope this helps.
Apr 07, 2009 | Tomtom ONE XLS Car GPS Receiver
Cannot acces my Tom Tom drive
Is the tomtom showing as an external drive if you access it via my computer on your pc.
If it is showing as a external drive you should be able to copy and past the files back to you tomtom
Just out of interest for what reason did you need to formatt your tomtom.
Jan 07, 2009 | Tomtom ONE 3rd Edition GPS
File Access Error
Check the SD memory card. There is a slider on the side of the card for locking to enable read-only mode. This slide should be up to enable read/write mode
Jan 02, 2009 | Tomtom One XL GPS Receiver
Go 710
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Dec 26, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
1,153 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
