Question about Frigidaire FGF326AS Gas Kitchen Range
Noisy convection fan
When we turn on the convection feature on our KESC307B Kitchenaid, it makes a loud noise and the entire stove vibrates. Is this a bearing problem or a loose fan blade? Something else?
Thanks for any help!
(Note: This does NOT involve the Frigidaire Gas Range in the column header!)
  • Anonymous Mar 16, 2014
    I need a manual for using a kitchenaid stove, which is gas and convection. So far I am getting nowhere
  • Frigidaire Master
  • 3,328 Answers
Could be both its within the fan
Posted on Jan 05, 2009
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Noisy computer fan
If its a loud "whirring" noise almost grindy...you need to replace that fan...it's about to fail. if it's a vibration type of noise, you should try tightening the screws first...if it's coming from processor fan, replace it before you fry your processor...
Jul 03, 2012 | Computers & Internet
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
I've a Sharp R-953. convection+ microwave makes a lot of noise
check the fan blade on convection, may be loose.
Oct 30, 2009 | Sharp Microwave Ovens
Convection/microwave makes noise and does not warm food
micro wave oven makes a whirling noise,fan blade may be out off balance and hitting edge of fan mout, slowing flow of air there are no other moving parts in the unit that i'm aware of.
Feb 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Bad fan noise from convection oven
THE ROD THAT HOLDS THE FAN BLADE IN PLACE IS WARPED BENT OR LOSE SOUNDS LIKE YOU BOUGHT IT THAT WAY EASY FIX! ORDER PART AND DO YOURSELF
Nov 16, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
Convection setting loud noise
try going to the place u bought it and see if they can tell u what to do with it. better safe then sorry
Jul 17, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Convection Oven Fan Failure
if the fan is cheaper you can replace it your self if it was making a noise id say thats where the trouble was
Jan 30, 2008 | KitchenAid KERA205P Electric Kitchen Range
Frigidaire FGF326AS Gas Kitchen Range Logo
1,057 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
