Fender Vibro King Pilot light out??
My guitar player noted a volume decrease in his VK and then the pilot light went out, amp is now dead silent
Thx for any help guys!!
  • 1,512 Answers
Hi superleaddud
MOst probable, is that an output tube went west(decrease in vol), and in turn popped the fuse(pilotlight went out). It is always a decent first bet that this is what has happened. You get generally 6 months out of a set out output tubes if you use the amp often, and at gig levels every week. I would first check and replace the fuse, and then the output tubes. GT 6L6GE are factory for that amp, and always a fair bet to use the same to replace them. If you cant extend to the budget for the GT's, then Russian made (Sovtek) Electro Harmonix make a decent quality tube that sound good in guitar amps. . Always replace them as a pair, and buy them gain matched. Get the Grove Tubes from a music store, and the Electro Harmonix from an amp repair specialist. Happy to answer any question you may have about the problem. Cheers. A FixYa rating is a great reward for my assistance to you.
regards
robotek
Posted on Nov 30, 2008
I replaced Can I change the tubes on my fender blues deluxe reissue from 6l6 to 6v6 power tubes
An internal component has failed. Without it in front of me for testing I cannot say which. You need to takje it to the repair shop.
Jan 28, 2016 | Fender BLUES-DELUXE-REISSUE Tube Guitar...
While playing through this amp I stepped on the channel changing footswitch and lost all sound from amp. all tubes and pilot light remained on but amp went silent. Disconnecting footswitch and cable f
Plug the guitar on the "power amp in" jack near the "presence" knob.
If you get sound, you have a problem on the preamp. If not, it´s probably on the power amp section.
Its a good start...
Dec 23, 2014 | Fender Hot Rod Deluxe Guitar Combo...
How do you check the tubes in a guitar amp
A vacuum tube tester is used to test tubes. Years ago, you could walk into an electronics store like radio shack and test your tubes. I suggest you take the amp to good music shop that repairs amps. They will be able to test the tubes.
May 16, 2014 | Fender Vibro Champ Xd Guitar Tube Combo...
When I plug the guitar into an mixing board/amp no sound comes out. From the mixing board, I can see that the mixer is receiving a signal but still nothing comes through the speakers. I own a Fender...
If the mixer is receiving signal, then the problem is pilot error at the mixer, not the guitar. You did not mention what type of mixer you have so I have no way of helping. Common problems would be failure to send the guitar channel to the mixing buss, leaving the channel muted... but we really need the mixer and model number to give more help that that.
Jul 18, 2011 | Fender CD140sce Acoustic Electric Guitar
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
Apr 23, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
How do I replace a fender 2 x 2 deville pilot light? CL
You unscrew the plastic dome over the bulb. The bukb is a bayonet base. Push in and turn... probably counterclockwise and extract the bulb. Replace by reversing the process.
Use T47 or #47 (6 volt) lamp... available at Radio SHack and other places.
Jan 23, 2011 | Fender R) Hot Rod DeVille III 212 Guitar...
I have a Peavey Valve King 112. When I plug in my guitar I get nothing.The power light is on and the preamp is on as well.There is just silince.No humming or crackling.
This could be anything. You could try swapping the preamp tubes. If it were a power amp tube problem, it is likely the mains fuse would have blown, Since the pilot lamp is still on, we will assume that the problem is at the preamp level. This absence of signal can be caused by a dead tube, or more complexly, by a faulty resistor or capacitor in the signal path. If you can't resolve the problem by swapping preamp tubes with a known good one, you should take the amp to a tech experienced in servicing tube guitar amps. Any good tech should be able to sort this out within an hour of labor time. I doubt it will require any expensive parts. It may even be as simple as a loose/bad connection, either from manufacturing, or from normal use. Pro tube amps are subjected to levels of heat, vibration and electrical stresses that consumer electronic gear never sees.
Oct 06, 2010 | Peavey Audio Players & Recorders
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
300 people viewed this question
 Grubhead
Grubhead
