Question about Maytag PYE2300AY Electric Dryer
How do I open the dryer to replace a loose belt?
My dryer is a Maytag Heavyduty Legacy series, how do I get into it to replace a belt?
  • Anonymous Mar 26, 2014
    My dryer was making a noise that sounded like a belt problem but them made a rather screeching sound for a while and is back to making a little noise. what do you think and how old do you think it is? I do not know because I bought a house with it already here.
    President:
  • Maytag Master
  • 2,651 Answers
There are 2 clips holding down the main top, approx, 3-4 inches in form each side of the main top where it meets the front panel. With a flat blade screw driver or a putty knife, youll be able to "pop" the clips and tilt the top backwards, form there there ar3 2 5/16screws holding hte front panel on within hte machine.
Posted on Dec 01, 2008
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
How do I open my Maytag dryer model # SDE305DAYW Legacy series?
Unplug
use a scrapper/puddy knife just under top find clips and push in on clips at same time pulling up on the top
Sep 17, 2014 | Maytag Dryers
Maytag legacy series dryer
most likely susoect is the belt pulley or a roller,if you send the model number i can help you out better
Jan 19, 2014 | Dryers
Maytag Legacy Series Electric Dryer
May need a new timer, I had to replace mine, easy job if you watch the video online.
Jul 08, 2013 | Maytag Legacy Series Top Load Washer
I have a Maytag Legacy Series dryer model mde308mayw where the drum doesn't turn. I'm assuming it's the belt, but this model does not have the screws on the bottom of the front panel. There are a couple...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 06, 2011 | Maytag PYE2300AY Electric Dryer
Maytag legacy series dryer starts and spins but will stop spinning after a few minutes
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Maytag Dryers
Hi, I have a Maytag gas Dryer, Legacy series, heavyduty. I clean the lint filter each time used but there is still a build up which I cannot get out unless I remove the filter housing. How do I do this?
you do not have to remove the lint housing all you have to do is go to an applaince store and ask for a lint brush you then take the lint brush and shove it down where the filter goes to loosen the lint turn on your dryer and it will blow it outside
Dec 26, 2008 | Dryers
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Maytag PYE2300AY Electric Dryer Logo
971 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
