Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I don't know how to scan a document on my epson DX4400,
I really need to scan a document now. Thanks
  • helpyadotcom Dec 05, 2008
    I don't know where the scan button is on an Epson DX4400
  • Anonymous Mar 25, 2009
    hvordan får jeg min epson (dx4400) scanner til at scanne
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a16
Posted on May 22, 2009
I cannot scan from vista to scanner
Posted on Nov 29, 2008
Where can I download a manual for Epson DX4400 Printer
Epson DX4400 Reference Guide
Setup Sheet
Basic Operation Guide
From the above links you can download the required document (in Acrobat pdf Format)
Hope it helps! Good Luck!
CreativeTECH
Apr 06, 2011 | Office Equipment & Supplies
I use Epson Stylus DX4400 and cannot edit scanned documents - they seem to be treated as photos. Also, I need to send the docs (from picture gallery) to Word but when I manage to do this, the text is in a...
They are photos. You need to use OCR (Optical Character Recognition) software to convert them to text, so they can be looked at in Word.
I don't know whether that machine comes with OCR software, but if not there are some free programs that can be downloaded. Check www.download.com
Apr 13, 2010 | Office Equipment & Supplies
Trying to install my epson stylus dx4400 multi printer without disk how do i do it
Hi
Ok I have put a driver for you to download from my website it is the driver you need this driver for
Epson-Driverdx4400+dx4450 and put the Epson Easy Photo Print
DX4400 and DX4450 will do the same drivers for your printer
Download your driver from my website click on the link and it will download for you.
Link=Driver http://www.4all2sell.com/driver/Epson-Priter-Driver-DX4400and 4450.exe
Link=Photo http://www.4all2sell.com/driver/Epson-Easy-Photo-Print-DX4400-And4450.exe
Please come back to gave Thanks and to let us know all is well
All Best: Pineworks
Mar 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Lost set up disc can not set up printer to laptop
Hi
All Best: Pineworks
Jan 28, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
HOW DO YOU SCAN?
You need some sort of photo editing program such as MS Paint or Paint Shop or any other imaging software. Open the program and click on Import. It will ask you which device or which TWAIN device you'd like to import from. Click on your scanner and you should be able to start scanning.
Apr 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How to scan on an Epson Stylus DX4400
To scan an image into your PC you need to use a piece of software called the Epson Scan Utility. This
comes on the installation CD with the printer but if you don't have the CD it can be downloaded from
Epson Support. For Europe:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84YT0DcLI1RrpNUFXBv2
99cYU003D
Or US:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Once it is installed it will put an icon on the desktop, or (if you have Windows) a folder in the Start
menu. Turn the printer on and start the Epson Scan utility (it doesn't work if the printer is off), it
can be used in 3 modes: Fully Auto, Home Use or proffessional. Fully auto is the simplest, just click
on the scan button. For the others be brave and experiment!
Please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Office Equipment & Supplies
Scanning on an epson dx4400
To scan a picture into your PC you will need the Epson Scan program installed on the PC. This program comes on the CD with the printer, but if you don't have the CD it can be downloaded from Epson:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cxyWBIk5wgudexhHWUK6Mnk&tc=6#19
It may already be installed, if you have Windows go to the Start menu and look for Epson Scan Utility. Turn the printer on and place your photo on the glass under the scanner cover. Click on Epson scan and you can choose 3 methods. Fully automatic, home mode or proffessional mode. fully automatic is the simplest method, simply click on the scan button. For the others be brave and experiment!
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 31, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How to scann photographic film fith epson scanner
Hi, I'm sorry to saythat this unit (DX4400) doesnt have the facility for film/negative scans
Dec 12, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
750 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
