Question about Panasonic Lumix DMC-LC33 Digital Camera
Blue Screen is All I Get!!
I have a Panasonic Lumix DMC-LC33 that has been having problems lately, but turning it on and off a few times fixed it. Now the camera won't come up at all, with a Blue Screen coming with no menu options. Does anyone know if there have there been any recalls on this unit? thanks, Jnnx
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Posted on Jan 03, 2008
  • 67 Answers
i'm not sure which one you have so here are both
Posted on Feb 24, 2008
  • 155 Answers
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
Posted on May 31, 2009
  • 1705 Answers
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Posted on May 02, 2010
  • 6831 Answers
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Oct 07, 2010
0 characters
1 Points
Menu instructions are now in Chinese! Cannot figure out how to get back to English. Please help.
Press the MENU button, use left/right-arrow to select the wrench-and-screwdriver icon in the upper-right, then use up/down-arrow to select the "i+" icon.
Feb 21, 2015 | Panasonic Lumix DMC-LC33 Digital Camera
Hi, I have a Panasonic DMC-LC33 camera. I have been trying how to figure out how to use the automatic timer....can you help?
OK, the manual covers this section in detail. Click HERE to navigate to download page.
Kind regards
Aug 31, 2010 | Panasonic Lumix DMC-LC33 Digital Camera
Cannot format a maxwell class 2 4 gb card for my lumix dmc-lc33
The DMC-LC33 is designed to work with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While it fits into the slot it will not work. You need to use SD cards, 2GB and smaller.
Aug 24, 2010 | Panasonic Lumix DMC-LC20 Digital Camera
How do I restore panasonic DMC LC33 restore factory settings ?
Page 77 of the manual tells you how (There's a lot of symbols and screen prints - so I won't cut and paste it here).
Seems fairly straightforward
User manual is here (free download):
Mar 09, 2010 | Panasonic Lumix DMC-LC33 Digital Camera
Error message
try Klomtrix trick this worked with my camera thanks klomtrix
Oct 25, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
Lumix DMC-lc33
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens. the ccd flex must be checked to see if it is plugged in.
Dec 29, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
i had the same problem , and i tried
Klomtrix solution on the same website, it worked for me thanks Klomtrix sethu
Oct 29, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Lumix DMC-LC33 system error
I had the same problem, just shake it abit ... I guess the camera is getting old and something is kinda of lose .
Aug 05, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-LC33 Digital Camera Logo
23 people viewed this question
Top Panasonic Digital Cameras Experts
Level 1 Expert
Are you a Panasonic Digital Camera Expert? Answer questions, earn points and help others
