Press the MENU/OK button. Press cursor-left, then use cursor-up/down to select SET. Press cursor-right, then use cursor-up/down to select DATE/TIME. Use cursor-left/right to move between fields, cursor-up/down to change them.
For more information see the "Basic Setup" section of the manual (page 14 in my copy). If you need a manual you may download a copy here.
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind.
How to set the time and date:
This unique watch can display month, date, time & minute.
1.Press A button twice. (Date and Time displays when press once)
2.When the month figure appears, press M to set the month.
3.Press A button once again, the date figure appears and press M to adjust the date.
4. Press A button once again, the hour figure appears and press M to set the time.
5.Press A button once again, the minute figure appears and press M to set the minute.
When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date.
Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Use this link and browse through my TIPS AND TRICKS:
http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
It looks like you've been pulling the crown halfway only. When you pull out crown to the first click - watch is in day/date setting mode. When you pull the crown further out (second click) - watch is in time setting mode.
Hi, To change / reset date and time touch on lcd screen, HOME > SETTINGS > CLOCK / LANG > CLOCK SET and set the date and time. Above said is mentioned in user manual of DCR-SR42 and you can download it from Sony Support.
When you pull the dial out, you can pull it out into two different settings. One will allow you to set the clock/time. The other will allow you to set the date (the day of the month). It took me a while to figure this out as well, even witht he manual.
ida-x100 car cd/mp3
