Question about Foxconn K7S741GXMG-6L Motherboard
Dead board. found the problem.when power supply burnt,it also burnt a chip on the board.could not see it till i took board out of case.thanks for help tho.
  • 624 Answers
He is refering to this posting: http://www.fixya.com/support/t128900-mobo_no_boot_after_changed_power_supply
Posted on Jan 01, 2007
Hello, lighting hit and my plasma Panasonic tc-42px24 will not turn on. completly dead. was told it maight be supply board??? thanks
Power surges wreck havoc with power supplies since they are first in line and bear the brunt of the rushing power. Try replacing the power supply board on the cheap by getting a used one on ebay to minimize the expenditure in case that is not it. Always a possibility,
Sep 09, 2015 | Panasonic Tc-42px24 42 in. Plasma TV
Asus g51v dead
it is dead sorry to say theres more than you can see. use a mag glass to see all board look for water trales burnt marks all before you try to fix it ok jim
Dec 03, 2011 | ASUS Computers & Internet
It wont turn on at all
Good day to mam wendy311!!!!
If you TV is totally dead set and no red light or green light on the front...
if that so the problem could be cause of dead set power power supply board...
You have 3 choices its either repair it on your own or took it to the technician or buy a new set of power supply board..
But for me I suggest to buy a new power supply board because if you took it to the technician cost of repair is almost or higher depends on the bad parts than the new power supply board...
But before you buy a new PSU please check this simple and common parts that usually cause of dead power supply board..
  1. Transistor----Check if shorted
  2. Capacitors----Check if bulged or leak.
  3. Resistors----Check if open or change value..
  4. Fuses---------Check if busted..
I hope this solution will be helpful..
Thanks for using fixya...
Aug 12, 2011 | Apex Digital LD4088 LCD TV
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
House took lighting strike and my LCD TV will not power up. Have TV apart and the fuse is good. Heat sinks are warming up and do not see any burnt spots or blown capacitors.
All the ICS on the boards are dead.Replaced the power supply board,it dead.Be prepare to replaced the Tuner board too.50% it dead also.Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes boards like the power supply board and the Tuner board.
Sep 30, 2010 | Philips Televison & Video
T2984 won't power up
I've re[lace alot of bad eMacines power supplies. Nearly all of them took out the video chip on the mother baord, rendering it useless.
Mar 23, 2009 | E-Machines eMachines Refurbished EMA...
Possible power supply burnt out
I've been hacking on a few of these monitors at work... we have a bunch that are dead... I have not seen this particular chip burnt (yet), but have been replacing a lot of the capacitors. To confirm the chip ID numbers you were looking at, I saw 4502C & AA5N0, and yes, they're both the same. If it comes to the caps, they should all have a flat top... if any are domed or black or sooty on the top, that is a good indication it is bad. Hope you had good luck with this. I can/t help with replacing just the chip.
Feb 02, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
No power
Bulb is definitely not cause of your problem.Normally lamp light will blink when it's defective.Dead means PSU problem .Some projectors have a overheat switch which switches off supply till manualy reset,you need to open the projector.
Samir
Oct 30, 2007 | BenQ PB6100 Multimedia Projector
Tv tube wont stay on
in 97 Sony had problems with Flyback on these sets, so the thing I would do different is change it, along with the other components
Aug 22, 2007 | Sony KV-32V42 32" TV
Samsung TXN3298HF 32" Flat CRT is dead, please help
Hi I have a Samsung Tantus Dynaflat 32 inch flat screen TXN3298hf that all of a sudden stopped working...no power no nothing. We opened up the back and found that a 5 amp fuse had blow. This fuse regulates that power supply to the tv and can be found at the end of the power cord prior to the circuit board. Hope this helps.
Jan 22, 2007 | Samsung TXN3298HF 32" TV
Foxconn K7S741GXMG-6L Motherboard Logo
73 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
WTF Chuck.....
WTF Chuck.....
Joe Negus
Joe Negus
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
