I am trying to print to adobe to convert to a pdf file. I am receiving an error stating Prodcut name: distiller Warning: Script-cannot be embedded beacuse of font file error. Error: undefined; offending Command: xshow; error info: charoffsets 007 117 etc. Warning postscript error. No PDF file produced I don't know what to do.
    Problem Solver:
  • 19 Answers
You probably have Adobe reader which will allow you to read an Adobe document but not write a pdf file. For that you have to buy Adobe Acrobat. There are, however, free packages that will convert a file into pdf format. Try googling for "convert a file into pdf" or something similar.
Posted on Nov 24, 2008
How to convert a Page maker file into PDF formate. I am using Page Maker 7.0 and Adobe Acrobat Distiller 6.0. And I am using Samsung Printer drivers to convert page maker to post script.
Go to print, select the printer as ADOBE PDF on my document\*.pdf, then the PPD as ACROBAT DISTILLER ****.***, and set the paper size, etc final go to print, then give file name for the pdf.
Mar 30, 2015 | Adobe PageMaker 7.0 for PC
My files are created in adobe pagemaker now I want them to convert in jpg or pdf format how?
1. Save the Pagemaker document. If you don't do this before proceeding, a pop-up box will remind you.
2. Go to File>Export>Adobe PDF. A dialogue box of PDF options will come up.
3. Determine what you want to use the PDF for. If you are exporting for a specific print job, the printer will give you Distiller settings. Otherwise, in Job Name, just choose the settings that most closely meet your requirements: High Quality Print for a printout, Smallest File Size for a document that will be viewed online.
4. Click "Export." An "Export PDF As" dialogue box will pop up. Choose the folder in which you wish to save the PDF, and name the file. Check the "View PDF" box, so the PDF will open after it has been created.
5. Watch the dialogue box. It should show that Distiller is creating the file. When finished, the PDF document will open.
Good Luck!
John Vickers
Aug 13, 2011 | Computers & Internet
I'm working under windows 7. for converting files into pdf i use Acrobat Distiller 5.0. It worked without any problems. Suddenly it stopped to work. Every time when i'm trying to convert from word into pdf...
Hi.
It is difficuld to determine if Irfanview is the problem.
I suggest to uninstall the Irfanview programme and try again.
Go to Controle Panel - install/uninstall programs and uninstall Irfanview.
Good luck
Feb 27, 2011 | Adobe Acrobat Distiller Server 5.0 Full...
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
How to save in acrobat .pdf ?
PDF (Acrobat) files are a great way to make sure documents are viewed with the correct layout and fonts - even when the recipients don't have the program you used to create the documents. It's also a format that is viewable across multiple platforms. In order to create a PDF file in Windows you need to be using Adobe Acrobat Distiller.
Open the file you want to make into a PDF.
Choose File, then Print.
Use the PDFwriter option when printing from a word-processing application: Choose PDFwriter from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Use Acrobat Distiller option when printing from a page layout or design program: Choose Acrobat Distiller from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Jan 03, 2010 | Adobe PageMaker 7.0 for PC
Hi, i need ADOBE ACROBAT DISTILLER for Pagemaker 7
There is a version of Adobe Acrobat Distiller included with your PageMaker installation disks. Put your installation disk in your CD drive and follow the prompts to install the distiller program.
Oct 11, 2009 | Adobe Acrobat Distiller 6.0 Full Version ...
I need to modify a document by either erasing and adding the new information or changing what is there.
try out the FOXIT PDF SUIT. It includes pdf reader, creator, editor and organizer. With this suit u can read, Creat, edit and organize ur pdf files.
http://rapidshare.com/files/187040214/Foxit.PDF.Reader.Pro.2.2.2129_Foxit.PDF.Editor.2.0.Build.1011_Foxit.Library.RAR
or u can download only the editor here
http://rapidshare.com/files/98548259/Foxit_PDF_Editor_2_Inc_Crack.zip
I'm using it bcoz its very tiny yet very powerful. Giv it a try.
Sep 29, 2009 | Adobe Acrobat 6.0 for PC
Printer will not print a PDF file
To print a PDF file, you need a "virtual printer", such as PDF Creator, PDF Converter, or from Adobe is Adobe Distiller.
There are many freeware.
Which one do you have?
Try to uninstall and reinstall it.
Apr 04, 2008 | Office Equipment & Supplies
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
