Question about Kenmore 22422 Top Load Washer
My machine will not spin.
The machine will agitate in the permanent press cycle. From there it just stops. It will not spin in any setting.
    President:
  • Kenmore Master
  • 2,651 Answers
Check your lid switch assy should hear a "clicking noise" when the lid is raised and lowered, if not theres your issue. the unit thinks the lid is up and therefore will not spin/drain for safety reasons
Posted on Nov 26, 2008
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
Will agitate, but won't drain or spin. Control timer seems to stop at that point of the cycle.
Sounds like a bad timer to me. Try a different cycle like permanent press or any other cycle to see if you have the same problem
Apr 13, 2010 | Whirlpool WTW5500SQ
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Kenmore 22422 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Robert Rankin
