Question about Brother MFC 420CN All-In-One InkJet Printer
Brothers Printers ink cartridges
When adding one new ink cartridge , itt cleans. How can I prevent this unneccesary cleaning ? Also, why do I need to add one color that is empty in order to print.
I have the same problem. I just discovered that if I turn OFF the power before I open the cover to check a cartridge it does not ask me if I just replaced it. I hope it was not just a fluke, otherwise I'll try unplugging the power next time, too. As for the "Can't print with an empty cartridge" problem; IE: Red is empty but you want to print with black; it is either that engineers don't know what they are doing at Brother or they are lazy or the managers are GREEDY. I think it is the last one. That is why I try NOT to buy "Genuine" Brother Ink cartridges. I used to refill them myself when I could find the ink, now I buy 3rd party cartridges. I pay $6.00 each for black and $7 each for color at a "Toner / Ink" shop about 1/2 mile from my office.
Posted on Nov 28, 2008
Clean the print head for an HP F380
If the cartridges are new, make sure you removed the, (sometimes clear), tape that the manufacturer places over the shinny metallic ink distribution slots, (shinny objects on the underside of the cartridges, like the previous answers have described). Otherwise, make sure the cartridges are the correct model for your printer, and I use a dab of alcohol on my q-tips to clean off old dried ink from the contacts. The contacts are very obvious once the cartridges are removed. Make sure to unplug the printer once you have removed the cartridges to access the contacts, before cleaning. And be gentle with the contacts, rub gently. And clean the cartridge contacts and ink dispensing slots as well, and gently as well. As previously mentioned, you should get ink on the q-tip when cleaning the ink distribution slots. Three colors, yellow blue and red from the color cartridge and black from the black cartridge. So clean the contacts first, then do the ink dispensers last to avoid adding ink to the contacts with a ink soggy q-tip. Good luck and be gentle.
Feb 13, 2015 | HP DeskJet F380 All-In-One Printer
I just installed new ink in my Brother MFC-465CN and the black will not print.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 16, 2010 | Brother MFC-465CN InkJet Printer
I have a brother mfc 5890cn and I am not able to print anything in black. The cartridge is brand new and I have cleaned the head several times. The other colors print out just fine.
Dec 01, 2010 | Brother MFC-5890CN All-In-One InkJet...
Have just installed a new black ink cartridge. message tells me to realign the print head How do I do that?
Nov 29, 2010 | Office Equipment & Supplies
My printer want print black but have a new cartridge i have a 946 dell printer ...it keep telling me right cartridge missing
You could clean the black ink cartridge. For this you need to remove the blank ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 16, 2010 | Dell 946 All-In-One InkJet Printer
Brothers MFC885cw can't recognize new cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | Brother Multi-Function Center MFC-240C...
I changed ink cartridges and now the printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 13, 2010 | Office Equipment & Supplies
Black ink will not print (new out of box).
If cleaning doesn't work you should talk to your retailer or Brothers support. Don't think they can expect you to use up all ink cleaning cartridges when the machine is straight out of the box..
Jun 01, 2009 | Brother MFC 6490CW InkJet Printer
Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Jan 26, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
