Question about HP Pavilion F1703 17" LCD Monitor
Power up problem
I got the monitor from my neighbor,who told me it turned on and off by itself.For about a month it worked fine,but began to blank screen and had to be turned back on to work. Now it doesnt stay powered on,when you first plug power input line in, the Power LED blinks a couple of times but then turns off... Any Help on this?
  • Bruce Quanz Jan 02, 2007
    Hey
    Thanks to this site I have repaired the Cold Solder joints at the coils and all is well
  • 9,156 Answers
Very good!
Posted on Jan 02, 2007
SOURCE:
I use an AT&T 2Wire 2701HG-B Gateway Modem and whenever I use the laptop wireless option, the modem tends to repeatedly reset itself, affecting internet use both on the laptop and a home computer which...
http://www.fixya.com/support/t4987959-att_2wire_wireless_router_keeps
Here is a solution I posted today for a similar issue. Might fix your problem.
Jan 13, 2011 | Computers & Internet
The monitor (Gateway FPD1975W) turns itself off after a couple of seconds. I have tried rebooting a number of times - same problem. When I turn the monitor off and then on again it works for a second or...
This sounds like the monitors power supply is failing. (if the monitor is truly right off) Use a flashlight to verify the back-light is not just the culprit. If you can see faint image in the monitor with the flashlight, then this would point tothe LCD inverter is failing. Its most likely the power supply board within the monitor itself. Typically It takes 3 35v 470uf capacitors to fix and a little patience to get apart. Do a bit of googling on "replacing the caps in a FPD1975W" and youll see what i mean. Cheers.
Sep 01, 2010 | Gateway FPD1975W 19" LCD Monitor
I AM WORKING ON BOARD TANKERS, I BOUGHT HP DV7-1135 NR. AFTER COUPLE OF MONTHS THE SCREEN GOES BLANK, JUST LIKE IT HAS NO POWER BUT THE HP LOGO ON THE BACK IS LIT AND IF I USE EXTERNAL MONITOR FOF MY PC,...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 28, 2009 | HP Computers & Internet
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Cuisinart DCC-1200 Coffee maker -
The machine is probably toast - but it's covered by Cuisinart's three-year warrany. Customer Service: (800) 726-0190. They charge $10 shipping, unless you live in California.
Jul 17, 2008 | Cuisinart DCC-1200 Coffee Maker
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
HP Pavilion F1703 17" LCD Monitor Logo
56 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
