Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Setspeakdefault window on startup in windows vista
Hi Sunil if i disable this command in msconfig will my audio still work or is there a switch i can use ie:- /q to stop window displaying
kind regards john
    President:
  • 2,110 Answers
No After disabling sound in msconfig u cant access sound...
Posted on Nov 29, 2008
When i turn on my hp pavilion a1220 n . in about 45sec's a pop up comes up and reads EZ Dock int easy uistring config xml failed . what is it and how do i fix it please?
if you have xp computer follow this step: start/run/msconfig and hit enter. system configuration window will open then click on startup/disable all/apply/ok
restart te computer and issue will be fixed//
if you have vista computer- start/start search/type msconfig and hit enter.
if you have windows 7 computer- start/search programme and files type msconfig and hit enter.
May 12, 2011 | Computers & Internet
Runonce exe -illegal operation on startup
Microsoft, Windows, Vista Home Premium, blank desktop, mesh, Ideal, personal computer ... Disabled all non ms-services and all startups via msconfig; ..... RunOnce: [*Restore] C:\Windows\system32\rstrui.exe /RUNONCE .... says "Windows Resource Protection could not perform the requested operation." ...
www.experts-exchange.com/.../Microsoft.../Windows/Windows_Vista/Q_23053429.html
Jul 20, 2010 | Microsoft Windows Vista Home Premium with...
I have a Dell desktop with Vista windows.Later it takes very long time to start and freezes a lot. since i switched from Cable to Verizon Fios about a month ago it is gotten much worse
You would installed a lot of softwares in it. By installing more softwares and programs, they were saved in startup. They start running when you start windows. You have to disable programs from startup. You can disable programs from startup by going on Start > Run > msconfig > startup > Disable all programs. Your computer's speed is boosted.
Jul 15, 2010 | Dell Computers & Internet
When i start my computer i git this Running error LogitechDesktop Messenger.exe
1. hit win+R to open "run" command window. (or) open "Run" window from start menu.
2. type "msconfig" in Run window.
3. click "startup" tab in msconfig window.
4. hit "disable all".
Restart the computer, now you wont find that error.
Hope, its helpful.
Regards,
Baskar
Jan 06, 2010 | Yahoo Messenger
This seems to be a common problem. The device seems to be trying to start or "boot" but will not function. The power button will not light up and the device does not respond to commands from computer. What...
Hi..
I suggest you to disable all HP related items, which will not startup at system boot up and might not cause any issues.
For Windows XP
Disabling HP Applications from MSCONFIG:
1. Click Start and select Run.
2. Type MSCONFIG and press Enter.
3. Click the Startup tab.
4. Clear the checkboxes for all HP related applications.
5. Click OK.
6. Restart the system.
You can restore any of the removed items by repeating the above steps and replacing the checks for the designated applications.
For Windows Vista
Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA
1. Click the Start icon.
2. In the Start Search text box located above the Start icon, type msconfig and then press Enter.
3. On the User Account Control window, click Continue. The System Configuration window displays.
4. Click the General tab.
5. Select the Selective Startup check box.
6. Verify that the Load Startup Items check box is not selected.
7. Click the Services tab.
8. Select the Hide All Microsoft Services check box.
9. Click Disable All.
10. Click OK.
11. Click Restart to apply the changes. The computer automatically restarts.
NOTE: After the computer restarts, a System Configuration message might display. If it displays, Ignore this message.
I hope this helps you...
Thanks..
Roger
Oct 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Freezing
hi
please follow below steps :-
1- disk cleanup in C drive. right click on C: drive and click on properties and click on disk cleanup button.
2- type TEMP in run command and delete all file in open windows.
type in %temp% in run command and delete all files in open windows
3- try to download superantispyware and smitfraudfix.exe for delete infected files.
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
http://siri.urz.free.fr/Fix/SmitfraudFix.exe
disable unwanted startup items from the MSCONFIG
type MSCONFIG in run command.
click on startup items then disable unwanted programs
Thanks
veeru_india
May 08, 2009 | Dell Inspiron 1501 Notebook
Express Gate - Wi-Fi - Not working
Its disable on youre startup.click start on search type msconfig .Click on startup tab and make sure its checked on.Hit apply and restart.
Nov 06, 2008 | Computers & Internet
How to make Vista faster?
You can try changing your Windows Theme to a more plain less animations ect..
To do this click on the desktop right-click now click on Personalise and now there are many things you can adjust to improve your computers performance like screen saver settings, wallpaper settings, theme settings and many more.
If your using the theme Vista Aero (with glass effect) then i would recommend you to change the theme to the Vista Basic theme.
The glass effect uses lots of your computers RAM and will slow it down dramatically.
Here is a guide so you can change your theme with example pictures so it's much easyier to understand what to do - http://grok.lsu.edu/Article.aspx?articleId=638
Good luck. Hope my solution was helpful.
Nov 03, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
