Question about U-Line Icemaker
Doesn't fill up
I've had my ice maker for 5 years and now it isn't making ice. I had the board replaced and it still won't fill up the storage bin in 12 hrs. Before it only took about 3 hours when empty. I was thinking maybe the water is overflowing and melting the ice becasue the ice it does make looks good.
    Problem Solver:
  • 10 Answers
Sounds like the ice is not releasing from the freeze plate before the waterpump comes back on. you can turn off icemaker - dry the plate with a towel - take fine steelwool and go up and down on the tray until all discoloration is removed and the plate is shiney - empty bin - flush plate and bin - turn back on and see if ice falls onto cutting grid either right before or right after waterpump comes on.
Posted on Dec 19, 2008
How to clean a scotsman icemaker
Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
1. Remove the kick plate.
2. Locate the condenser surface.
3. Vacuum the surface, remove all dust and lint.
4. Replace the kick plate.
1. Open the door and turn the ice machine control knob off.
2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
4. Turn the ice machine control to ON.
5. Allow the machine to operate for about 2 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin interior.
10. Replace the ice removed in step 2.
The ice scoop should be washed regularly, wash it just like any other food container.
WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
May 16, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
Ice maker is leaking water and storage bin is building up with ice.
I could use a little more here on this, like the make and model and year, but if I have to guess I Would suspect the ice mold is split and the ice maker would have to be replaced, we have seen several of these that leaked up a round the head area, assuming the ice maker is level.
You could remove the ice maker from the freezer and sit it on your counter and make it level. Put a little water in the mold and watch it drip / leak.
Some models you can adjust the fill valve to slow the water down if it fills to quickly they can splash and cause a buildup
Other models there is a fill cup that needs changes out if this starts leaking.
If you can give me more info as to where it is actually leaking, we can go from there.
Aug 24, 2011 | Refrigerators
I just emptied all the ice out of my ice bin to take on a picnic, but now my ice maker won't make more ice. I have had it for 5 years with no problems. What happened? Did some setting get bumped? or...
1. Check to make sure the when you removed the ice bin that you did not leave the lever by the ice tray in the up position. That is the one the stops the making of ice whe the bin is full. This is the only easy solution.
2. Check to make sure that the vent between the freezer side and produce bin is closed. This is used when opened to keep that bin colder than the rest of the fridge. If that isn't it then there a few easy solutions.
Jul 02, 2011 | Amana 22.6 cu. ft. Side-By-Side...
English instructions for saivod fhs186 ice maker
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
3. The condenser.
5. The ice scoop.
and the storage bin is empty.
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
1. Clean the machine as explained on the next
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker sprays water into the ice storage bin
you need to remove the i/m from the freezer and make sure the "fill cup" doesnt have an ice blockage. thats where the water has to funnel into the mold. it can get a drip into the cup and then freeze in the cup. clear it out once and try it again, but if it happens once or twice again , then you might have to replace the water inlet valve.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
 Is the ice dispenser stalling while dispensing “crushed”
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
U-Line Icemaker Logo
79 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
