Question about SanDisk Sansa m240 MP3 Player
Load music on my sansa m 240
I try to load music on my sansa m240 but when i conect  it to my computer i receve a message sansa is connected and that is all. my PC doesn't reconigze my player. can you help me ?
  • coler1 Dec 02, 2008
    WMP will detect my sansa m240, and show how much space is left on the device, but it says there are "no songs" on the device. So now I can't remove any songs to make room for others. It had been working perfectly. Thanks for any help!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
I don't know how to delete all the music from my sansa scandisk m 240 device
the fastest way to do this is to connect it to your computer go into the computer screen right click on the device and choose format..
Jul 12, 2010 | SanDisk Sansa m240 MP3 Player
How do I edit my sansa m240 without the appropriate software?
You can connect the Sansa m240 to your pc, and in my computer you shall see the player. You can add music by dragging the mp3 files to the music folder on the player. You should see your other music currently on the player, in those folders.
Jun 06, 2009 | SanDisk Sansa m240 MP3 Player
I dont have a disk or manuel for my sandisk sansa m240 how can i download music to it? I have the usb cord tho.
Follow these steps to drag-and-drop music files to your Sansa player:
1. Connect your Sansa player to your computer.
2. Open Windows Explorer.
3. Double-click on your Sansa player.
4. Double-click Internal Memory if you are using WMP 11 or double-click
Media if you are using WMP 10.
5. Drag and drop music files from your computer to the Sansa player’s MUSIC
folder.
Dec 10, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 player
I dont know if the mac is the same as windows, but plug it in. Go to my computer. You should see Sansa m240, or F:\, or a personalized name (right click and click rename). Copy the songs you want and paste them in the player. It should pull up a message that says copying. When it's done, you can unplug it and listen to your music
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
Toget soft ware
You don't need external software for the m240, everything should be on the player, check that when the USB is connected that is says MSC if you are having problems with the connection otherwise if you have a different problem or can be more specific, let me know
Mar 15, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 and itunes
Probably not, try going to where the songs are all stored [My Music] select all the songs and open with the Sansa converter-to transfer music or use Windows Media Player.
Otherwise open My Computer then SansaM240 folder and drag the songs into Music.
Dec 25, 2007 | SanDisk Sansa m240 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
161 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
