Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leappad model 57-000 does not match up stylus to book that is in
Leappad does not respond to stylus
It could be one of several things, a system reset, a firmware update but it sounds like a screen cable has become disconnected or similar fault. Before doing anything, is it still under warranty, if so its best to go back to the vendor or leapfrog and request an exchange. Here's the url to their support page.
http://www.leapfrog.com/en/pages/support/product_pages/LeapPad.html
If the warranty is out of date, then its down to dismantling the pad and looking for ribbon connectors which may have come adrift.
Jun 03, 2012 | LeapFrog LeapPad Learning System:...
I have a LeapPad model 57 that has 8 books with it and only 2 will work. I know they go to the LeapPad system I have because on the books that go into the LeapPad show the same picture as the LeapPad...
Given two sets S and T we declare S<T.if there is a mapping of T onto S but no mapping of S onto T is possible .prove that if S<T and T<U then S<U.
Nov 11, 2010 | Computers & Internet
My leap pad won't recognize any of my books. When I put in a new cartridge it says, "Oops! That's not a leap pad cartridge!" If it does comprehend me pressing the green go button, it starts reading a...
I just had the same exact problem. We followed the leap pad recommendations for cleaning the stylus connection. Then we used a q-tip to clean the cartridge port and blew into it. Now it works.
Oct 23, 2010 | LeapFrog LeapPad Learning System:...
My leappad plus writing won't respond when i press the go puttons on the books.
If it does power up, and you are unable to get only the Go button not to function, there could be 3 problems
1. the cartridge is dirty
2. the sytlus is bad
3. the sensor membrane is wet or bad.
Clean the cartridge or try another book.
Replace the stylus.
Dry out the leap pad (this is a last resort. place the leapPad in a sunny window for a day, standing upright and open (remove batteries).)
If nothing else works, you can find another leapPad at most thrift stores (that works!), for about $5-$25 (any model, but you might not get a lot of model choices, but some even come with books and cartridges you might not have!)
Take a book and a cartridge with you, maybe even batteries, and ask the store if you can try it before you buy it (they will usually let you test it)
Sep 21, 2010 | LeapFrog Leappad Plus Writing
Leapfrog Leappad Learning System book. Regardless of what book/cartridge is inserted, it only plays "Lil's Loose Tooth" the book not in the system. We've turned it off, replaced the batteries. I don't...
Try cleaning the other cartridges contacts with alcohol and Q-tip. The major problem with the leappad is that the cartridges are failing after the warranty period is over.
Jun 11, 2010 | LeapFrog LeapPad Learning System:...
When my child tries to use the pen to choose anything it is no longer working.
They recommend that you try cleaning the pen. Unplug the stylus pen and wipe both the plug and the jack with a dry cotton swab. On most LeapPad systems you can remove the pen via the battery compartment.
If the pen still does not work you can order a replacement stylus pen for $5, which covers shipping and handling.
Simply call Consumer Services at 1-800-701-5327, and order a new pen.
Hope this helps. Please let me know if I can help you with anything else.
JimmyC
Oct 03, 2009 | LeapFrog Leapster Electronic Book:...
LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
200 people viewed this question
Top LeapFrog Computers & Internet Experts
Alun Cox
Michael Cummings
Level 1 Expert
k24674
Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
