Question about LG Shine KE970 Cellular Phone
Water damage LG Shine
I dropped my phone in a snowbank this morning outside my office. Once inside I wiped it off with a cloth as there were a few drops of water on it.
When I went home at lunch I realised I had a missed call, but none of the buttons on my phone were working. The display shows when someone calls, and the power button works, but that's all.
Currently it's open and upside down and the battery is out....anyhting else i can do? Is it going to get better?
  • kms29 Jan 22, 2009
    I also have the same problem -- my phone got wet from snow and is now not working.  I let it dry out for three days, and then worked for a little while, and now the phone turns on and off, but only the power button works.  Please help!
This may sound crazy, but it has worked for every phone me or my friends have had water damage to.
Take the phone apart as far as you can go (like take off the silver plate backing and take out the battery, and simcard) and place it on a dry rag and put it in the oven. Then heat the oven to its lowest setting. My oven can go as low as 175 degrees, so what I did was to open the top a little bit to let the heat out. Believe it or not, this heat shouldn't ruin the phone, but only dry up the water that is blocking the circuits. Be very careful though. The ideal temperature is about 125 degrees.
Considering water boils at 212 degrees, it SHOULD take more heat than than to actually damage your phone. Leave it in the oven, turned off, for 24 hours or longer. Give it some time... be patient. Then try turning it back on. It has worked for me and my friends, as of now we are 5/5.
Good luck.
Posted on Nov 25, 2008
I dropped my phone in the toilet. the sceen was trying to work but it didint. so i burried my phone in a bag of rice with no air for 24 hrs and the next morning it worked
Posted on Jun 20, 2010
  • 3 Answers
I inadvertently washed mine (with a 15 min. soak cycle) and then it actually went into the dryer (accidentally) for 15 min. I thought there was no hope at all when I saw the moisture inside the screen and everywhere else, but I followed the advice to remove the battery and bury the phone in a bowl of dry rice for 24 hrs. Although the old battery does not work at all anymore, the phone works with a new battery and the screen looks dry inside. Frankly, I'm amazed.
Posted on Aug 31, 2009
Hair dryer then container with either rice or a couple of silica gel bags!
Posted on Nov 26, 2008
Frigidaire microwave model ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep.
Hopefully no one sprayed a liquid cleaner directly onto or near the keypad...
From page 23 of the owner's manual:
"Wipe the microwave oven inside and out with a soft cloth and and warm (not hot) mild detergent solution. Then rinse and wipe completely dry."
"Clean the outside surface of the microwave with soap and a clean damp cloth. Dry with a clean soft cloth. To prevent damage to the operating parts of the oven, do not let water seep into any vents or openings."
If there is moisture damage, it may dry out by itself if you leave it overnight with the door open. If not, the warranty would be voided and you'd have to arrange for out of warranty service.
If there is no moisture damage, and it failed not due to outside forces, then you should contact the manufacturer to arrange warranty service.
Oct 05, 2016 | Frigidaire Over-the-Range Microwave
Tip
How to properly clean and care for your airpot
To clean your airpot you have to first make sure that it is turned off and unplugged. Pour out the water that is still in the airpot if there is some and allow it to cool down. Once it has cooled down you can begin to clean it.
You want to start with a since of the inner lining using hot water. Use a sponge to get loose debris off the lining and rinse again.
Fill the pot up again with hot water and few drops of mild dish soap, let this solution sit for 10-15 minutes. Using your sponge again scrub the inside of the pot then make sure to rinse both the sponge and the inside of the pot to get all the soap out.
If there are any mineral deposits in the pot you should fill it with hot water and about 2 Tbsp of white vinegar. Let it soak for about an hour an then rinse thoroughly you don't want the taste of vinegar in your water.
To clean the spout you pour some of the water and vinegar solution out the spout then rinse with fresh hot water.
Finally to clean the outside use a damp cloth to wipe it down and a dry one to wipe it dry. in the case that you have stains on the outside use a mild dish soap to clean, rinse with clean cloth and then use a dry one to wipe dry.
on Oct 06, 2013 | Home
Dropped LG shine into a bucket of water
if it was just pure water leave the battery out and let it dry for a few days in a warm dry place if not wash it out with warm water and let it dry this has worked for me a few times in the past hope it works for you
Oct 31, 2009 | LG Shine KE970 Cellular Phone
Keypad is jammed
http://www.fixya.com/support/r3771170-phone_water_damage
Aug 23, 2009 | LG Shine KE970 Cellular Phone
I dropped my LG Shine in water recently. I
The battery must have caught moisture. Thus it can't take sufficient charge. Try replacing the battery.
Aug 14, 2009 | LG Shine CU720 Cellular Phone
Black screen on inside and outside has not been dropped may have water damage from water on my hands
i know the water sticker is still white because you didnt get the actual sticker wet... in order to get the sticker to turn red... the sticker has to be wet...!
May 29, 2009 | Motorola Mobility RAZR V3
LG Shine Bluetooth problem with motorola S9 stereo headphones
all you gotta do is disconnect the device in the bluetooth menu and reconnect that way the lg shine will recognize the right ear piece. at&t wouldnt release a product if it didnt work. the only problem is that at&t didnt say it in there instruction booklet
Sep 05, 2008 | AT&T LG CU720 Cell Phone - Silver
Freezing
sir have u accidently dropped the phone.. probably in water.... ok check whether it has full charge.. once again switch on the mobile.. if it doesn't switch on better take it to local service station. thank u sir
May 09, 2008 | LG Shine KE970 Cellular Phone
Water spot on outside door
you need to clean the stainless steel with good tetergent and hot water to clean the steel
ss wipes do not do much good and only put a film of oil on the surface
once you clean surface with soap and water use a stainless cleaning cloth you can buy from cleaning store
use the with just water and wipe dry
keep the cloth in a plastic bag to keep from drying out
Feb 01, 2008 | LG LDF8812 Stainless Steel Built-in...
LG Shine KE970 Cellular Phone Logo
1,448 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
