Question about Sanyo VWM-800 VHS VCR
Tape is stuck
Hi, i have my tape stuck in the vcr. i managed to get it out. however, the tray was still stuck in the position as if the tape was inserted. i force the tray to come up into its initial position. but know i still get the flashing light and tape doesn't get played and when push the tape in, the tray looks loose. any idea why i still get flashing light; you said earlier it could be the teeth are off or something. if this is the case, what would suggest
    Scholar:
  • 168 Answers
I think u broke some parts in the tape loading mechnism or u misaligned the initial position of the mechanism. thats why the error is still there. some switches still activated. i suggest that u bring it to a qualified technician if u dont know anything about this.
Posted on Jan 17, 2007
Vcr/tv how to get the carriage unstuck
It sounds as if the drive belt or wheel that controls the carriage has perished and failed. There is normally a micro switch on the side or rear of the tray, that senses the presents of a casset. If it is closed with stikky tape or clay you may be able to simulate a casset in the machine and with manual force help the casset to open or close. alternatively a small lamp in the centre of the tray senses the tape. then you have to cover the lamp or two sensors on left and right side of the tray, to prevent detection of the broken or missing tape.
Nov 15, 2015 | Televison & Video
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Putting main deck line cover back on inside vcr
this sounds like the carriage tray, it's the metal plate that the vcr slides in and out. It should have a door on the front side and it may have at least 2 screws and sometimes four. The only problem is aligning up the tray to be exact. in the power on mode the vcr tray should be pushed outward like the tape is sticking partly out of set.
Sep 01, 2007 | Televison & Video
VCR tape stuck
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Dec 18, 2006 | Zenith VCS442 VHS VCR
Flashing "2" on VCR front panel.
Hi Oshaman. I have dealt with many VCR's and would like to ask you a few questions before diagnostics. How exactly did you get the tape out of the machine ? There are several tape threading gears involved, and if you accidentally made one of them skip a few teeth while forcing the tape deck up the "position" switch will send erroneus signals to the tape threading position switch/ controller. Was the tape rolled around the capstan/pinch roller ? Did you have to force the tape loading tray up to extract the tape ? Feel free to email me. pemere@optonline.net. Happy Holidays.
Nov 11, 2006 | Samsung SV5000W VHS VCR
Sanyo VWM-800 VHS VCR Logo
117 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
